What Does this Mean - #4CYL at 25% - Do I Need a Valve Job?
Old Mar 9, 2007 | 06:52 PM
Matt in AR's Avatar
Question What Does this Mean - #4CYL at 25% - Do I Need a Valve Job?
OK - the saga continues:
BACKGROUND: 8 weeks ago my 98, 3.4 v6 4x4 started to run rough when warm and at an idle. Plus, my gas mileage has gone WAY down & at one point the check engine light even came on.
REPAIRS TO DATE: So, in an effort to remedy this I have run the codes and done/replaced the following: tune-up (plugs & wires), intake manifold gasket, 02 sensor, coolant thermostat, cleaned MAF, done complete intake leak & vacuum leak test (no leaks).
RESULT OF ABOVE: Though the check engine light has not come on again, I still have the rough idle and lousy gas mileage.
SO in a last ditch effort, I (gasp) took it to the dealership and paid them for diagnostics and this is what they came back with "test-drove vehicle w/a scan tool, all sensor values were within spec, leak tested each CYL & found CYL #1,2,3,5,6 at 10%, found #4CYL at 25%."
QUESTION: What does that mean to you - the dealership says it means a $3000.00 valve job! Any thoughts.
My next step is to clean the IAC.
Old Mar 9, 2007 | 07:43 PM
BruceTS's Avatar
that means your getting 10% loss in all your cylinders except #4, it has a 25% loss... It may just need the valves adjusted, hard to say.
Old Mar 9, 2007 | 08:05 PM
alexe's Avatar
usually anything over 20 and a delership will want to pull the head. when you say rough do you mean a little vibration or was it misfiring?
Old Mar 10, 2007 | 03:50 AM
Matt in AR's Avatar
No, no misfiring - just a rough idle. Rough enough that coffee in a cup in the dash cupholder sloshes around and the kids in the back seat says it feels like an earthquake.
Old Mar 10, 2007 | 04:14 AM
Maj's Avatar
Maj
Not sure what kind of vacuum leak test was performed but a vacuum gauge will usually fluctuate when you have leaky valve(s). The 25% down cylinder is a problem and should be addressed whether it be leaky valves or bad rings.
At $3k for a valve job, I would be tempted to shop for a junkyard motor. Tearing into your motor and doing just the valves might be a bit of a waste depending on the condition of your rings and bearings.
Old Mar 10, 2007 | 04:19 AM
Stevo3's Avatar
Try some seafoam, and let it sit over night. Try a cheap remedy first. There just may be build up on the valves. And im sure it wouldnt hurt to try
Old Mar 10, 2007 | 05:14 AM
MTL_4runner's Avatar
Originally Posted by Maj
Not sure what kind of vacuum leak test was performed....
It is a leakdown test (positive pressure not vacuum).
I agree that 25% might be worth looking into on #4 but I have a tough time saying that your extremely rough idle is all because of that. I am very curious what CEL came on briefly but I guess unless it comes back, who knows. Have you also done a resistance test on the injectors? If not you might want to try that as well. Make sure you spray the MAF with brake cleaner because I found that the electrical contact cleaner wasn't getting the job done.
Old Mar 10, 2007 | 08:33 AM
Matt in AR's Avatar
Brake cleaner & seafoam - OK< I am on it - worth a shot.
CEL has not come on again since I replaced the intake manifold gasket.
Old Mar 10, 2007 | 08:41 AM
alexe's Avatar
i would also try doing a wet compression test. that will indicate whether its your valves or your rings. a wet compression test is just pouring a small amount of oil in the cylinder after testing, then retest, if your compression goes up, its rings, if it stays the same its valves. i mean a small amount, no more then a capfull of oil.
oh and check your motor mounts, shaking that bad without a misfire sounds like a busted mount
foampile
Dec 18, 2022 01:29 PM
Blamalam
Mar 12, 2022 07:34 AM
he's gone
7
Dec 3, 2019 07:08 AM
montanatruck
Feb 26, 2017 07:07 AM
Poppie51
Jul 23, 2015 05:03 PM
