what to do next...
Old Jan 1, 2004 | 01:49 PM
playboy's Avatar
what to do next...
I want some more power out of my 22R. I was conserdering a few option but not too sure. Im not sure if it would be worth it to do out the 22R and maybe rebuilt it. Or to swap a 302 or something into it. any idea's??
Old Jan 1, 2004 | 03:24 PM
toy283's Avatar
Get a hold of , Ted @ engnbldr.com. He'll help you squeeze every available horse out of a 22R. Good man to deal with as well.
Old Jan 1, 2004 | 04:40 PM
Plays_with_Toys's Avatar
Just to be sure it is the "22r" (carb) not the "22re" (efi) correct?
I have read that weber carbs help power increase. Also a bigger cam.
Old Jan 1, 2004 | 04:53 PM
Los Gatos?'s Avatar
Here are some ideas:
If you have an early 22R you can swap on a 20R head (lots of info on this, search this site and the web) this can also be done with more difficulty on a late 22R block (need different pistons + you have to enlarge oil holes in the HG so they match up... yuck)
Higher lift cam
larger valves
weber 38mm synchronous carb
2.25" exhaust (mandrel bent + turbo muffler)
Downey or comparable header
cam gears (3* advance)
you can also advance the timing a little bit (watch for pinging) or if you really want to, bore the cylinders out a bit and increase compression by decking the block or head or getting custom pistons.
Old Jan 1, 2004 | 07:32 PM
playboy's Avatar
where would a good place to buy a weber carb? or maybe a header from? I live in Canada. Maybe an online store or something. How about some do it yourself upgrade web sites?
matt1992
9
Dec 13, 2013 04:02 PM
Gamefreakgc
Dec 7, 2013 10:26 AM
cheftank
Oct 17, 2013 06:07 PM
ChefYota4x4
Jun 11, 2012 03:17 PM
Batman
7
Jan 4, 2012 07:24 AM
