what do i need to clear 35s on my 3rd gen
Old Nov 2, 2006 | 12:08 PM
calrockx's Avatar
Originally Posted by bamachem
a fat bank account, and as a minimum (to do it right):
2" suspension lift (more in the rear would be better)
1" body lift (minimum)
8"-wide wheels w/ at least 4.5" or less backspacing
shaved upper A-arms
power steering fluid cooler
poly steering rack bushings
transmission cooler
regear to 4.88's or 5.29's
tundra calipers, pads, and rotors to stop the additional rotational weight
cut and welded/patched firewall at the rear of the front fenders for clearance
cut the rear of the front fenders
cut the stock or aftermarket front bumper at the wheel well
remove all mud flaps, running boards, etc.
remove all bolts from the rear of the wheel well (rear bumper/flab bolt)
you should also consider steel front and rear bumpers, sliders, & front/rear lockers, and a winch to take full advantage of the additional ground clearance. if you don't already need these, then you should ask yourself if you really NEED 35's.
Good List.
Old Nov 2, 2006 | 12:32 PM
ADH8796's Avatar
shaved upper A-arms
transmission cooler
Why do you need the body lift? TLT did his with no body lift and no rubbing. Just curious.
Old Nov 2, 2006 | 12:40 PM
ADH8796's Avatar
Unless your talking about fitting 35's without doing the mods he did?
Old Nov 2, 2006 | 04:49 PM
Bighead's Avatar
The body lift will decrease the amount of trimming you will have to do when compared to what TLT did. I have a 1.5" BL with almost everything bamachem listed and still rub a bit up front at full stuff.
Old Nov 2, 2006 | 05:03 PM
  #25
d0ubledown's Avatar
but he also hacked out alot of metal...which probably wouldnt have been much of a rubbing issue if there was a body lift installed.
Old Jan 28, 2008 | 02:20 PM
  #26
cmarch97runner's Avatar
you will definitely need 3 and 3. go with the roger brown 4crawler 3" body and maybe a downey or revtek for the rear suspension. i also did the tundra swap but you will also need coil spacers. this setup will give you enough clearance for a mall crawler.
for trail riding, you're gonna have to put a little more elbow grease into it. not a one day project. i have done a couple of inches of trimming to both front and rear fenders, and some major cutting in the wheel well so i don't stuff it, but carefull enough to where i don't shoot stuff up near the engine. sorry i don't have exactly what i did, but thats a start. and no pictures of the trimming yet. but it IS possible.
Old Jan 28, 2008 | 02:38 PM
  #27
EWAYota's Avatar
Holy Old Thread.
Old Jan 28, 2008 | 02:44 PM
  #28
Bighead's Avatar
Originally Posted by EWAYota
Holy Old Thread.
Yep and with incorrect info included.
cmarch97runner: since this thread is at the top now, you can do the 315s with less than the 3" suspension and 3" body lift you used...there are several on this board that are proof of this...me included. And I don't "mall crawl".
Don't assume that the the way you came up with is the only way to do it.
Old Jan 28, 2008 | 02:48 PM
  #29
EWAYota's Avatar
Not uncommon.
Old Jan 28, 2008 | 05:02 PM
  #30
well, when i tried it with 5", it was a no go. just goin by what i've seen in front of me
Old Jan 28, 2008 | 05:13 PM
  #31
d0ubledown's Avatar
...you were doin somethin wrong then. im only running 2.75" suspension lift, and 1.5" body lift, and 1.5" front wheel spacers to clear my 315's.
tall is only good for mall crawlin...nothing else.
Old Jan 28, 2008 | 06:04 PM
  #32
of course my rims are 16x10. hey, i'm definitely not trying to be a know it all. i have 6" and without cutting, i got enough flex to maybe clear a curb. but i haven't seen everything.
and i'm going for a 97. not all 3rd gens.
don't give me too much ish. i'm still trying to learn here too.
Old Jan 28, 2008 | 08:05 PM
  #33
AxleIke's Avatar
He don't lie either. That truck gets used.
Now, hows about getting out here soon man!?!?! LOL
Old Jan 29, 2008 | 02:35 AM
  #34
Bighead's Avatar
Yeah, yeah....
For some reason I thought once I retired I would have more free time.
Old Feb 19, 2008 | 04:57 PM
  #35
Saw it today. 3rd gen IFS 1" BL running 35s. there you go. i proved myself wrong. from now on i'm going to start everything with "in my opinion" or "from what i've seen around here".
hope everything works out.
Old Feb 19, 2008 | 08:31 PM
  #36
Jdizzydub's Avatar
Originally Posted by lee
power steering cooler and tranny cooler are two very important parts
Are they because of the added weight to lug around??
Old Feb 19, 2008 | 08:35 PM
  #37
NwRunner's Avatar
im running stock suspension with 30/9.50/15 bfg muds. When im fully flexed out with the wheels turned i have about an inch or so before i rub. i dunno exactly but the math but thats something to go off.
Old Feb 19, 2008 | 08:52 PM
  #38
Jdizzydub's Avatar
I'm running 2.75 OME lift up front with LC coils OME out the rear under a 2in RB BL and I still rub at full crank on the rear of my fenders. I've started grinding down my UCA's and trimming towards the firewall. Eventually, I'll do most of the other mods before wheeing it. I don't mall crawl, but I wanna make sure i do it right. Here's the trimming I've done, etc
[IMG][/IMG]
[IMG][/IMG]
Anyone know a good place for Tranny and PS coolers??
terminator
Oct 13, 2021 10:13 AM
Jun 1, 2021 01:51 PM
Rasteirinho
Nov 6, 2017 03:40 AM
mskalmus
May 28, 2017 07:51 AM
digitalracer
May 16, 2016 03:57 AM
