what did you pay for a valve job?
Old Jun 17, 2005 | 11:54 PM
lucky3's Avatar
how much did everyone pay for a valve job, especially the 3.0
Old Jun 18, 2005 | 12:03 AM
jimbo74's Avatar
mine was $180 for my 22r, but i took the head in to the machine shop, they checked it for leaks, ground the valves, and replaced the seals and decked the head
i have heard around $1500 for the 3.0
Old Jun 18, 2005 | 05:36 PM
kyle_22r's Avatar
holy cow, that's a lot. the machine shop i go to charges $80 for a valve job on a 22R head(if you bring it in to them)
Old Jun 19, 2005 | 11:00 AM
jimbo74's Avatar
kyle i live in CA, the bay area part..... you cant buy a house in this area for less than 500k...... that was actually the cheapest i could find, most places wanted $300
Old Jun 19, 2005 | 12:52 PM
kyle_22r's Avatar
still that's robbery. if your valves aren't fried too badly(or don't mind replacing them) it's a piece of cake if you have a valve spring compressor...
Old Jun 19, 2005 | 12:56 PM
jimbo74's Avatar
they also decked the head, well at least made it flat, cleaned it up, replaced the valve guides and did a valve grind.... thats what it costs out here.... this shop also came highly recomended from a mechanic frined of mine.... whenever my truck has a problem even i in my infinite knowledge cant figure out, he is the first guy i go too.... its good to have friends that know what they are doing... and help you out for free when they are working
Old Jun 20, 2005 | 10:14 PM
jscarrozzo's Avatar
The head off my 93 22re is in the machine shop now. Said it won't cost me anymore than $100 when they are done. They are cleaning it, and checking for leaks. Assembling it back up and swapping out the seals.
Old Jun 20, 2005 | 11:28 PM
viperdan's Avatar
Just how bad should your compression be before deciding to have the valve job done?
Old Jun 20, 2005 | 11:54 PM
Ganoid's Avatar
Compression is a combination of ring condition and valve sealing.
Run a leak down test ideally to determin wich is at fault.
A trick I use instead of a leak down (no leak down equipment) is taking a compression guage hose with the quick connect on it and removing the check valve from the bottom. Run the cyl you want to check to TDC making sure both valves are closed or if you dont want to pull the vave cover just make sure the Dist rotor is pointing in the right direction (this will assume an Ignition event on a power stroke). Then screw the hose into the cyl like you are going to check compression but instead of putting the guage on the end of the hose try connecting an air hose with the regulator down around 20psi. If you have a bad valve you will hear the air escaping from the exhaust or the intake depending on wich valve. If its rings you will hear it in the intake through the PCV valve but you can pull the oil cap and know for sure if its comming out of the crankcase. Its not the best but I use it with good success.
foampile
Dec 18, 2022 01:29 PM
Blamalam
Mar 12, 2022 07:34 AM
he's gone
7
Dec 3, 2019 07:08 AM
montanatruck
Feb 26, 2017 07:07 AM
jerusry
Oct 19, 2015 05:28 PM
