Went wheeling, heard a noise..
Old Aug 5, 2003 | 06:53 PM
ssbogger's Avatar
I was one my way home and decided to take a 30min detour. The trail consisted of alot of small rocks, very bumpy, and I used 4lo and 1st or 2nd gear to be easy on the clutch. Well I would hear a noise that I can best describe as a 2lb metal ball rolling around on top of my skid plate. It sounds like more of a thump that a clang. It only happened about 12 times while on the trail and only when it was bumpy. I dont remember if it happened only when I was on the throttle or not. I have the diff drop installed if that makes any difference in the diagnosis.
Any input is appreciated even if its a "I couldn't tell you what the hell that is."
Old Aug 6, 2003 | 06:42 AM
mtnfreak's Avatar
Did you look on top of the skidplate to see if there were any 2lb metal balls rolling around? Anything else in there that might be making noise - loose shaft, sway bar...? Anything external that makes noise is probably going to leave a mark, so look for anyplace that's rougher or shinier than the rest of the truck.
(Please note that I avoided the all-to-easy jokes about your truck having/needing balls.)
Old Aug 6, 2003 | 07:55 AM
ssbogger's Avatar
Ill try anything to get rid of the noise, but not a sex change for my 4runner.
Old Aug 6, 2003 | 08:07 AM
bamachem's Avatar
Maybe it's a 2lb ROCK that's rolling around on your skidplate...
Old Aug 6, 2003 | 08:27 AM
4x4runner's Avatar
I've had the same problem for a long time on my runner. I think I saw a post a while back that attributed it to something in the steering mechanics.
Old Aug 6, 2003 | 08:33 AM
AznSky's Avatar
I would say take off your skid plate, and check to see if anything's loose under there.
edit: It might be really tough so have some pb plaster and maybe a breaker bar handy in case you need it.
Old Aug 6, 2003 | 10:28 AM
ssbogger's Avatar
I'll probably try this. The bolts shouldnt be too tough, I just took it off a few weeks ago to install the diff drop.
glowz825
Jan 25, 2022 09:28 AM
kouki420
Sep 2, 2015 11:42 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
