Well the new lift should be installed soon BUT
Old Jan 30, 2005 | 05:48 PM
GodwinAustin's Avatar
this is freakin me out:
WARNING –– TACOMA LIFTING LIMITATIONS
If you let Toyota sell you a Tacoma with Automatic Differential Disconnect (ADD) - shame on you! These vehicles are limited to approximately 2” of suspension lift. These vehicles do not have manual unlocking hubs, consequently the front axles and CV joints spin 100% of the time the vehicle is in motion. Beyond 2” of lift would put the CV joints on sufficient angle to buzz you out of the cab at highway speeds (not a problem in off road terrain where the speeds are slower and/or the CV joints are constantly changing angle).
I drive ALOT on the highway at 70-75mph - am I going to be getting buzzed out of the cab because of CV noise?
anyone out there running a 2.5" lift with ADD and having problems driving on the highway as far as increased noise?
help!
Old Jan 30, 2005 | 05:49 PM
socal98runner's Avatar
How about 4" of total lift and no problems.
Of course, I got a diff drop to help with this problem.
Localmotion's Avatar
i would think a Roger Brown Diff drop would solve this?
Matt
Old Jan 30, 2005 | 06:11 PM
Good Times's Avatar
get the standard 2.5" - 3" lift that everyone has and then get the 1" diff drop by Roger Brown and you'll be perfectly fine.
Old Jan 30, 2005 | 06:29 PM
there seem to be mixed information out there on the diff drop mod; there is no straight answer- some people say it does little or nothing to change the boot angles... - some say it saves tons of wear and tear....the argument can be seenhere
ground clearance is negatively affected
so - I did order a diff drop - but I dont know if I will put it on or not.
Old Jan 30, 2005 | 06:34 PM
User 051420's Avatar
Put it on...You'll definately want to. I don't see exactly how it reduces ground clearance, as there is a crossmember even lower...
I have 2.5" of lift with a 1" dd. No "buzzing".
Old Jan 30, 2005 | 06:42 PM
Neil - make any sense?:
Quote:
Originally Posted by Kyota
Does the drop require you to take off your skid-plate or something because it goes too low? Other than that, I dont see how it suck up clearance...???
Beside that, what harm can it do? Probably doesn weigh enough to have the body lift effect when runnin your truck hard.
It reduces the ground clearance of your skid plate since the diff now sist lower. It's right on the skid plate and you need to get longer bolts for the middle skidplate mounts or just bend the crap out of the mounts with the shorter bolts.
Old Jan 30, 2005 | 06:54 PM
My RB diff drop came with the longer bolts, yes. However, I did not use them, nor did I bend the crap out of my skid plate. Lots of people run these, it isn't a big deal.
Originally Posted by Sonoran Steel
DOES NOT lower your skid plate or require you to slot the holes and use longer bolts.
Old Jan 30, 2005 | 07:35 PM
Duc Hunter's Avatar
Do 4Runners have the same problem? I thought the new Taco was based on the 03- 4Runner but I have not heard anyone talking about this problem with the 4Runner?
Old Jan 30, 2005 | 08:25 PM
Good Times's Avatar
Duc Hunter, I believe he's talking about his 97 taco.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
