weird squeak
Old Jan 18, 2003 | 11:32 PM
joshik's Avatar
weird squeak
i have this weird squeak that comes from under my truck. sounds like towards the front. it happens when i shift. if im stopped, and i take off quick, its a loud SQUEAK... and if i let off the clutch and down on the gas slow, its a soft squeak. it doesnt happen all the time. try to think wat it could be. im maybe thinking its the traction bar????? i was going to remove it and then drive it around the block. but any other suggestions? could the tranny squeak?
thanks
Old Jan 19, 2003 | 03:56 AM
rpeAMP's Avatar
I have a noise that is similar to this. Basically what happens (usually only in the low gears), when I don't let off the clutch fast enough or I give it too much gas while I'm letting off the clutch, that noise ensues until the clutch is all the way out. Are we talking about the same thing?
Old Jan 19, 2003 | 04:53 AM
UKMyers's Avatar
Are these noises external and being caused by your engine torque moving something? From your description almost sounds like it's the clutch itself. A bad throw out bearing will howl like that.
Old Jan 19, 2003 | 07:40 AM
joshik's Avatar
rpeAMP it seems like its what you said. but it doesnt keep squeakin until you let off the clutch complete. it only lets off a quick soft/loud squeak. it sounds like it could be coming from the engine torque moving something. UK, could my clutch squeak?... a bad throw out bearing, is that REALLY bad? do i need to get a new clutch soon?
thanks!
Old Jan 19, 2003 | 07:53 AM
MonkeyElvis's Avatar
hey guys... i had an annoying noise similair to this, and it turned out to be the slave cylinder pushing on the fork that comes out of the bellhousing (not sure what thats called) I just put some grease where the piston hits the fork and it shutup. anyways...get near that slave cylinder and have a friend push the pedal.... maybe this is the same problem
Old Jan 19, 2003 | 09:06 AM
joshik's Avatar
oh yeh, my clutch squeaks too, when my trucks off, and i push down the clutch i can hear a squeak. i dont kno if thats what my initial squeak question is though. but thanks monkey, coz mine does that too and ill look into it.
josh
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PBRaddict#1
Sep 22, 2015 07:50 AM
JamesDINAN
Sep 22, 2015 05:37 AM
Bill854x4
Sep 20, 2015 04:32 PM
