Weird noise drivers side dash
Old Aug 23, 2009 | 11:59 AM
bign90's Avatar
Hi All.
I am new here and did a search but cannot find an answer. I just bought a 99 Tacoma 4wd in Belize. When I speed up to 45 + I hear a noise in the drivers dash that sounds like a popping, klunking noise. It almost sounds like a vacuum pot being pulled in, losing its seal and the bellow popping out..
The truck had 120 k and I was wondering what preventive work should be done? The roads in Belize are poor to say the least and I have had the suspension checked and ball joint, bushings, etc have been replaced and in good shape. The rear shocks are missing the rubber bushings and will be replaced
Any help would be appreciated..
Mark
Old Aug 23, 2009 | 12:02 PM
bign90's Avatar
more info
I forgot to mention that I rev'ed the engine to the same rpms to simulate 45+mph to see if it was a vacuum leak but heard nothing. It only does it when the car is moving
Mark
Old Aug 23, 2009 | 07:32 PM
fornesto's Avatar
Check the inner lining of the driver's front wheel well. I had a similar strange noise. It was a flap banging against another flap, only at high/mid speeds when the air blew hard enough in there to pull it back. The flap had rotted a bit and a corner had ripped away from the rivet. This sounds strange, but take a look.
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
crashburnoveride
Jul 10, 2015 06:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
