Weird gas guage issue...
So yesterday I was just driving along, and all of the sudden my gas guage Plummets to below empty, and the gas light starts flashing. So I stop, turn off the car, restart, it hovers around half a tank, then same thing. So I knew I had half a tank so I continue with my day.
Today, it just goes up to way above full, then down to below empty, and stays there.
Only thing different than normal driving was I was towing a trailer for the first time, with the trailer lights hooked up. The trailer wiring is fine, and I was using the factory connector.
Ideas?
Ideas?
If you understood the search function, You would understand you can find 287582 threads like this, Because its been discussed tons of times !!
What does posting off of a phone have to do with it..?
Sure, Ill just do the damn search for him..
https://www.yotatech.com/forums/f2/s...t=Gas%2A+Gauge
https://www.yotatech.com/forums/f2/3...t=Gas%2A+Gauge
https://www.yotatech.com/forums/f2/f...-issue-163080/
Was that hard ? No, Because you let other people do the searching for you.
it is a common occurrence with the 3rd gen Runners.
If yours never got taken in for the Tech Service Bulletin it is likely too late. Just be religious in resetting at least one trip odometer and refill way before you need to. You will learn to gauge your range conservatively to avoid walking for gas.
Many of us typically fill up at 13 some gallons or thereabouts and the tank holds 18.1 but can not or should not be run completely dry.
I have had the same issue with my 99 4Runner. As was stated above, use your trip odometer at fill up. I did a ton of research on the issue and the repair is very costly. It's one of those things that is not worth the cash to repair IMHO. I just refill the tank at 175 miles.
trailgoat
Aug 13, 2015 05:54 PM
icentropy
Jul 14, 2015 10:23 AM
