Weird engine whine
Old Nov 28, 2007 | 04:41 PM
Bird333's Avatar
Weird engine whine
I have a '98 4-cyl 4Runner auto. It has about 140K miles on it. I am hearing an engine whine that seems to follow my pressing the gas pedal. It kinda sounds like a cross between a whine and the engine fan blowing. Can you guys offer some advice on what things I should check or have checked?
Thanks!
Old Nov 28, 2007 | 04:45 PM
Whitey13's Avatar
Probably alternator related.
Old Nov 28, 2007 | 06:40 PM
ninjarunner's Avatar
maybe you accidentally installed a supercharger????
Old Nov 29, 2007 | 06:34 AM
Bird333's Avatar
I wish.
Old Nov 29, 2007 | 06:35 AM
Bird333's Avatar
I'll get the alternator checked, but it doesn't sound high pitched. Any other thoughts?
Old Nov 29, 2007 | 10:29 AM
MTL_4runner's Avatar
Use a mechanics stethoscope to narrow down where the sound it coming from.
When you find the offending part, you'll know right away.
Old Nov 29, 2007 | 10:00 PM
stormin94's Avatar
Check your fan clutch. If you've got one.
Old Nov 30, 2007 | 08:34 AM
Skrillah's Avatar
Belts?...Keep us posted on what you find...
Old Nov 30, 2007 | 08:40 AM
rdlsz24's Avatar
Check your accessory pulley bearings on the front of the engine. Also check your power steering fluid level. Mine whined like a cat after my headgasket replacement because I forgot I had drained it
Rob
Old Nov 30, 2007 | 08:43 AM
Nate08's Avatar
It has to be a supercharger
Old Dec 14, 2007 | 12:02 PM
balverson's Avatar
Had a similar whine on '96 Tacoma. Pitch changed according to engine speed.
Narrowed it down to either the tension pully/bearing assy on the compressor
or the compressor/bearing itself. Have not repaired yet. Loosened tension
on the idler/tension pulley to stop whine until I can fix.
Old Jan 28, 2008 | 01:04 PM
fire5's Avatar
I might have a similar problem...how is it alternator related?
Old Feb 23, 2010 | 04:41 PM
JWaldz's Avatar
bringin back a dead thread... having the same issue on my 3.4 (auto) I dont think it's power steering bc I can sit parked and rev my engine and it will whine. Maybe alternator, my truck died a couple times last week for some reason, and now this hmmm? My belt needs changed cus every time It's real cold outside my belt will chirp when I start it up. I'm thinkin maybe the bearing in the pulley has gone bad or possible fan clutch related. Any thoughts or suggestions? Need to get this fixed asap.
Never heard the outcome of the OP's problem and I'm assuming by now it's fixed.. what was the deal? Thanks
JWaldz
Old Feb 24, 2010 | 03:15 PM
JWaldz's Avatar
Anyone? Noise is getting worse
Old Feb 24, 2010 | 03:22 PM
1990yota-pickup's Avatar
spray wd40 on the alterenator,
put you ear as close as possible to the nose.
Old Feb 24, 2010 | 04:17 PM
JWaldz's Avatar
Well, I think I can cancel out the alternator. If you're looking at the engine it's coming from the left side of the engine. Maybe a pulley is going out?
Old Feb 24, 2010 | 05:05 PM
DD423's Avatar
i just had the same issue check your timing belt bearings...replace that and it fixed mine
Old Feb 27, 2010 | 05:25 PM
JWaldz's Avatar
Got some time today and stopped by the closest mechanic shop , Midas. Guy used a auto stethoscope or whatever it is called and we pinned it down to being the AC Tensioner Pulley. Guess bearing is bad on it, should be an easy fix.
Old Feb 28, 2010 | 05:10 AM
get it fixed,
Old Feb 28, 2010 | 03:45 PM
JWaldz's Avatar
Did it today.. 30 dollars advanced auto and 30 minutes garage time
