way to fix bolt threads?
Old Aug 17, 2005 | 06:43 PM
4Crawler's Avatar
Try applying some anti-sieze compound (silver metallic grease) or even plain old axle grease. The lube will help the tight spots slide past each other and you might be able to see where things are rubbing to tight (the grease or anti-sieze will be worn away there).
Old Aug 17, 2005 | 06:48 PM
r0cky's Avatar
That's a good idea, Roger, thank you!
Old Aug 17, 2005 | 07:41 PM
Rivalred's Avatar
Could heating it up help it along?
Old Aug 17, 2005 | 11:53 PM
94x4's Avatar
Guest
Start it and run it down the bolt as far as you can rOcky, then back it off and take a look at the threads on the bolt and in the nut to see what sort of shape they are in, clean if necessary, then rethread it as far as you can again and then back it off.
Keep this up and you'll eventually get it to where you're having no problems at all threading the nut onto the bolt, although it will remain somewhat tough to do as it is a "nylock" style nut.
Patience and perseverance rOcky, the squirrel always comes through.
p.s. I'd of used a grinding bit in the Dremel and "conicaled" the end of the bolt to insure that I would get a clean start on it..., as I've had to do before.
Old Aug 18, 2005 | 05:01 AM
  #25
shiftless89's Avatar
you get it fixed?
Old Aug 18, 2005 | 08:30 AM
  #26
e rock's Avatar
Heat = death for nylock nuts. Plus it really stinks.
Old Aug 18, 2005 | 08:36 AM
  #27
Rivalred's Avatar
Just the thread, but metal is a conductor to heat and it would melt... Your right.
Old Aug 19, 2005 | 07:39 PM
  #28
garrett1478's Avatar
hows it coming rocky?
icentropy
Sep 16, 2020 02:47 PM
DrZero
18
Jul 24, 2015 11:31 PM
Yota.Jay
Jul 23, 2015 08:08 PM
jon.r
Jul 11, 2015 03:34 PM
