VSC/A-TRAC Warning Lights
Old Sep 24, 2004 | 04:32 AM
broknlgs24's Avatar
i forgot to include goodtimes.
goodtimes - there is an autozone right around the corner from me. i am gonna attempt the MAF clean 1st, if taht doesn't do the trick, i will head to autozone.
Old Sep 24, 2004 | 07:31 AM
Good Times's Avatar
either way the code will pop back up until you clear it w/ the obdII scan tool.
thus it's easier to just find out which codes are being triggered and then clean/repair the item and then clear the codes
good luck
Old Sep 24, 2004 | 08:10 AM
broknlgs24's Avatar
ah, i did not know that. i just assumed that once i cleaned the MAF, the CEL and other lights would go out. that is, of course, if that is what's causing the problem to begin w/.
thanks goodtimes!
Old Sep 24, 2004 | 11:54 AM
4-RUNNIN' FREAK's Avatar
I am starting to remember something else. After I cleaned the whole engine bay, I had those problems. Now when I was cleaning the contacts, I got to the MAF and cleaned it stuck it back in, no click. So I pulled it and with a closer look I noticed the gasket on the harness was warped. I trimmed some out and stuck it back in and heard the click. I cleared with my OBDII scanner, and no more problems.
Old Sep 24, 2004 | 12:20 PM
  #25
Citykid's Avatar
Broknlgs, no none of the lights were on. I'll drive it this weekend and on Mon take it to Autozone. still can't figure why it came on in first place though. I got the 'click' when putting it back.
Old Sep 25, 2004 | 11:06 AM
  #26
broknlgs24's Avatar
i just returned from Autozone.
My Code is P1135.
I've since removed the MAF Sensor and cleaned it. To me, it did not look that dirty, but, i cleaned it anyway. I found a site detailing the removal and cleaning; however, my MAF Sensor did not look anything like the one pictured. Mine looks similar to a match, but metal. there is some sort of substance at the top. What is that?
Old Sep 27, 2004 | 04:51 AM
  #27
broknlgs24's Avatar
anyone w/ a 2001 have a pic of their MAF? i took a pic of mine and will attempt to get it posted shortly.
i've also been reading where replacing the O2 sensor may help. i was checking out URD and noticed that they list 2 O2 sensor part #'s. would both be needed?
thanks in advance,
brian
Old Sep 27, 2004 | 08:19 AM
  #28
Citykid's Avatar
Didn't getting you codes pulled re-set the computer and turn off the lights?
Old Sep 27, 2004 | 08:29 AM
  #29
broknlgs24's Avatar
citykid - r u saying that once AutoZone pulled the code, the CEL should've went out; regardless of whether or not i cleaned the MAF?
Old Sep 27, 2004 | 09:00 AM
  #30
Citykid's Avatar
That's the impression I got. Maybe I'm wrong.
Old Sep 27, 2004 | 09:11 AM
  #31
lee's Avatar
lee
no, i believe the lights go out when the computer is reset after the problem is fixed. resetting the computer before it is fixed SHOULD make the lights come back on when it re-senses the same problem.
Old Sep 27, 2004 | 09:23 AM
  #32
broknlgs24's Avatar
lee- by any chance do u have a pic of ur MAF sensor? did u read the description of my MAF? from the write-up that i read and the pic that they had, mine looked different. i notice that u too have a 2001.
Old Sep 27, 2004 | 09:42 AM
  #33
Good Times's Avatar
once you clean the maf sensor, use the obdii scan tool to clear the codes.
if you don't clear the codes, the CEL will come right back on.
Old Sep 27, 2004 | 09:48 AM
  #34
lee's Avatar
lee
i dont, but if no one can provide one, i'll try to get one to you tonight when i get home from work.
Old Sep 27, 2004 | 10:03 AM
  #35
Citykid's Avatar
Okay, code P0446 came up.
"The PCM has determined that a malfunction exists in the electrical circut for the vent control in the evaporative emmision control system"
1-Purge or vent solenoid defective
2-Possible blockage in vapor canister or ECAP line
3-Check connector and wiring.
I have no idea what this means or how to attack it any suggestion? And your right, the code didn't clear. I must have mistaken that for the obdii that would clear out the lights. And I do not have one.
Old Sep 27, 2004 | 10:45 AM
  #36
lee's Avatar
lee
https://www.yotatech.com/forums/show...ighlight=p0446
Old Sep 27, 2004 | 02:58 PM
  #37
broknlgs24's Avatar
here's a crappy pic of my MAF. notice the substance at the top. it sort of looks like a caramel/sap type of substance.
Attached Thumbnails VSC/A-TRAC Warning Lights-picture.jpg
Old Sep 28, 2004 | 07:51 AM
  #38
broknlgs24's Avatar
does any1 know if that is what a clean MAF should look like for a 2001 4runner?
Old Sep 29, 2004 | 07:08 AM
  #39
Citykid's Avatar
Just got back from the stealership...
"Scanned system and received fault code P0446. Fault traced to EVAP canister malfunction. Removed and replaced EVAP canister assy as needed."
Labor: $212.50
Parts: $338.84
Total: $599.59
Old Sep 29, 2004 | 07:16 AM
  #40
broknlgs24's Avatar
ouch!
