VSC/TRAC Question
VSC/TRAC (Andy Mod 2.0) Question/Issue
Need some advice. I have the AndyMod 2.0 done on my 01 4Runner. It was working fine...the VSC was overridden and both dash lights illuminated, which told me that the VSC/Trac were disabled. I went to swap out the bulbs, and now the lights don't stay on and the VSC/TRAC arent disabled anymore. Both the VSC OFF and VSC TRAC bulbs illuminate briefly upon startup of the truck, but don't stay lit. I also spun the tires on gravel yesterday and the orange slip indicator light came on when the tires slipped. The "VSC OFF" light DOES still come on when I use the center diff lock. Not sure if i'm looking at a wiring issue somewhere but don't get what pulling the gauge cluster out would screw with and why simply pulling the gauges frigged something up.
Update...checked the wiring everything was connected so I tried this......While the truck was running, I unplugged the connector from the computer, took off my switch and just left the wires dangling. The VSC and TRAC lights and the ABS lights on the dash illuminated. Plugged the connector back in, lights remained on. Then I shut the truck off and restarted it but now none of those lights remain on ...mind you, currently the red wire with the black tracer is just cut and not connected to anything so in theory, the VSC and TRAC SHOULD be disabled. Not sure whats going on here.
80seriesftw
Mar 5, 2016 10:08 PM
FinallyOffRoad
Feb 19, 2016 06:29 AM
TRD
Feb 12, 2016 01:32 PM
