viper security system help!!
Old Oct 6, 2002 | 06:27 AM
slimafroshady's Avatar
just got a viper security system in my car. it is the viper 300 esp... well i get in my car this morning, and the ignition turns on, but i try to shift into drive, and the stick wont move!! i have a 2000 4runner... the only thing that is working in my car is the HU... the engine souns fine, but everyhing is not registering. the odometer doesnt register, the gas gauge doesnt teither... the ac will not turn on.... is this some kind of protection mode?? how do i get it out?? thanks!
Old Oct 6, 2002 | 07:14 AM
Eric D.'s Avatar
Is that the remote start one? If it is, try to start it manually. Mine acted funny alittle also a plug ceom off of the brain. But mine is a stick so I can still drive it around. Hope this helps...sorry if it doesn't.
Old Oct 6, 2002 | 03:56 PM
cybrenergy's Avatar
I had a 600 ESP Viper system installed in my truck last weekend. It has been working great so far. Did you install your system yourself or did you have somebody do it? If somebody did it they should cover the problems that you are having.
Old Oct 7, 2002 | 09:27 AM
Duffdog's Avatar
check your ignition 3 wire
If a shop did it, go back there!
It sounds like someone inadvertantly cut the Ign 3 wire instead of the starter signal--which would cause the no tranny problems. if not, then well that really sucks!! better take it back to the dealer if the shop cant fix it. I dont believe the viper300 even has remote start unless you add the 500V system to it. might be cheaper to just get the entire 550 in the first place.
regards
Tim
Old Oct 7, 2002 | 09:34 AM
cybrenergy's Avatar
I was going to get the 550 but really determined that I was not going to use the remote start functionality much. You need to remember to leave on the heat or A/C the night before, etc. Just seems like a waste of money to me.
Maybe if I lived somewhere super cold, it would be worth while.
coryc85
Dec 5, 2015 08:42 AM
Obmi
Nov 24, 2015 11:37 AM
Williamemslie
14
Oct 5, 2015 09:28 AM
highonpottery
Sep 14, 2015 12:46 AM
shalom
Sep 8, 2015 10:02 PM
