Vent Visors on 2003 4runner problem
Old Aug 21, 2003 | 01:46 PM
rayh78's Avatar
Anybody eles have a problem installing Vent Visor (by weathertech)
Only problem is on drivers window works in regular mode. But when I try to put glass up by the automatic mode it will go completely up but then comes back down and stops half way.
Thanks
Old Aug 21, 2003 | 01:53 PM
Woodbert's Avatar
I think if you close it without the auto and hold the up switch for about a count of five it will reset and then the auto will work right.
It's because of the anti-pinch feature.
Old Aug 21, 2003 | 02:47 PM
Bob_98SR5's Avatar
Ray,
Its an easy fix. What is happening is that there is not enough space in between the ventvisor and the rubber window gasket (or whatever its called).
You'll have to make a "shim". I made one out of a sliver of wood and paper. Jam the shim in between the ventvisor and the rubber window gaskets (on each side of each window) and leave overnight. You should not have any problems the next morning.
Bob
Old Aug 21, 2003 | 04:14 PM
Sac State's Avatar
Or in the INSTRUCTIONS it says to auto up the glass and place your hand in between the glass and window seal, forcing the glass up slower until the auto mechanism 'registers' the 'new' auto stop location. Ah, do what Bob said.
Old Aug 21, 2003 | 06:49 PM
rayh78's Avatar
Thanks all
I have the shims already in place for 24 hours and if that wont work will try the new auto stop
mskalmus
May 28, 2017 07:51 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
elwood73
Jul 5, 2015 07:07 AM
