Using 2WD trans in 4WD 2001 4Runner??
Old Mar 18, 2010 | 02:17 PM
daugherty83's Avatar
Question Using 2WD trans in 4WD 2001 4Runner??
Looking for a used transmission for my 01 4x4 4Runner. Is it possible to use a tranny from a 2wd 2001 or 2002 4Runner. I thought the tailhousing's were different and the 2WD wouldn't bolt up to the transfer case?
Old Mar 18, 2010 | 05:36 PM
bump for the night crowd.
Old Mar 18, 2010 | 05:50 PM
BajaRunner's Avatar
Pretty sure the output shaft on the 2wd tranny will be different than that of a 4wd tranny
Old Mar 19, 2010 | 07:07 AM
DeathCougar's Avatar
I remember learning something about square peg round hole in kindergarten.....but I digress.
How mechanically inclined are you? Ie, how well would you be able to basically rebuild a transmission? If you have never gotten into auto transmissions, I wouldn't bother trying to swap a 2WD into your 4Runner. If you have swapped tcases and rebuilt transmissions before, it should be a pretty straightfoward swp. It is NOT a bolt on swap by any means.
Old Mar 19, 2010 | 09:44 AM
I won't be doing any of the work concerning the trans. LOL I am simply bringing a donor tran into my tranny shop and letting them install. I was just curious, as to whether or not a 2WD trans could possibly work in a a 4WD 4Runner. I didn't think it would work at all, but figured you guys would be the ones to ask. Thanks.
Old Mar 19, 2010 | 09:53 AM
Toyota transfer cases are not divorced, so you have to find like type for like type.
You COULD use a 2WD transmission. You would no longer have 4WD.....with a 2WD trans....but that goes without saying.
Old Mar 19, 2010 | 12:38 PM
Thanks Cougar
mskalmus
May 28, 2017 07:51 AM
Road Bull
Oct 10, 2015 04:55 PM
andrewtexas123
Jul 14, 2015 04:29 AM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
