Uses water when outside temp is cold
Old Jan 20, 2013 | 07:30 PM
A.walton's Avatar
I have a 97 4runner completely stock 3.4 6 cylinder. I've checked the oil and its not milky. It has a constant steam and uses water when the outside temperature is 60 degrees or below. Ive racked my brain trying to figure it out and can't find anything mixing. Any suggestions on what the problem could be or something that I could check?
Old Jan 21, 2013 | 12:11 AM
wyoming9's Avatar
Red face
Have you pressure tested the cooling system.
If it is losing coolant and it is going out the exhaust you have a either a bad intake gasket or a head gasket .
If you have a leak in the heater core you would smell the coolant in the cab:jessica::jessica:
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
rjtrials
Aug 6, 2015 07:25 PM
Jonny246
Jul 12, 2015 04:51 AM
Avenged
Jul 9, 2015 07:55 AM
