(used) URD Kit Install help
I would very much appreciate if anyone can help with these questions. I've had the supercharger in for almost 2 years (lightly driven) and I finally got the URD Split Second box with ESC and the 318cc injectors off ebay (I did buy the Walbro fuel pump and IK22 spark plugs new from URD direct).
Can anyone help with an install diagram/instructions specifically for the Split Second box? I can't find one on the URD site.
Does the Split Second box get a vacume line input on a 96-98 motor? If so from where?
Any way to put in the fuel injectors without pulling the supercharger manifold (that would be great not to have to do)?
Thanks for any insight.....
You will have to pull the s/c to install the injectors. I recently installed my URD kit. Here is a link for the install directions:
http://www.gadgetonline.com/U-Tune.pdf
You should contact URD and tell us that you bought this kit off of Ebay and that you bought a fuel pump from us. Tell us exactly what year, what truck, and what tranny you have and ask for the installation instructions. We will be happy to help you out.
Support@URDUSA.com
The FTC box does need to be connected to the boost port on the supercharger. It must have this so it gets the proper vac/boost signal for its load scale indicator.
You can go to my site, www.GadgetOnline.com and in the supercharger section there is info on how to find the boost port.
Gadget
Support@URDUSA.com
Gadget
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
