upgraded wire harness NOT WORKING
Old Jun 17, 2003 | 10:47 AM
white sr5 runner's Avatar
i just bought a heavy duty H4 wire harness from suvlights.com. I read the review from the toyota tech page and it seemed very easy to install. I grounded the wires, attached the new wire harness female plugs to the male part of the bulbs, and then attached the wire harness to the battery. I followed the wire up exactly. I even attached to fuses to the end of the wire harness. I put in 20a.
After everything was installed, I never got anything to happen. I didn't blow a fuse and i didn't get any light. I replaced the wire harness female plugs with the factory female plugs and the bulbs lite right up. Not sure what happened.
Is there anything that i can look for to see if the harness if working? I grounded the wires to the sides of the engine walls where there are pre-threaded holes. I have used the same holes for aux lights and the grounds worked fine.
Any help or suggestions would be great
Old Jun 17, 2003 | 10:54 AM
Cebby's Avatar
So you get no lights and Phil gets hitgh beams only? Nice QC at suvlights.com
I think we need another vendor for these items...
Old Jun 17, 2003 | 11:09 AM
pfdaxe's Avatar
suvlights are a good company. Did you try calling them?? It would make better sence than posting here. I would call rather than email. They have always been very helpful over the phone. Talk with Jen
Old Jun 17, 2003 | 12:22 PM
i did contact them, but i also wanted to know if anyone else has had a problem
Old Jun 17, 2003 | 01:47 PM
pfdaxe's Avatar
I had a simliar porpblem when I first installed my HIDs from them. I called and they told me to reverse the connection. That worked for me but that was a different system but it was a simple fix....whew
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Yota.Jay
Mar 6, 2016 11:02 PM
TheManOutside
Jun 18, 2015 03:32 PM
RTdawgs
Jun 1, 2002 06:36 AM
