Two Noises ( YES I searched)
The first I believe is my exhuast. When I searched, I read all about the exhuast rattling, and the outer shell, and thought for sure that had to be it. I got under mine and checked everything out. I don't have an outer shell, and I just can't find where the exhaust is making noise. It is all rubber mounted and when I give it some muscle, I can't hear any metal to metal at all. What should I do next? The noise is an annoying rattle that I can hear with the windows down, and feel with them up. It peaks right before it shifts into 2nd.
The next noise just started after I greased my drivetrain. It is a squeak that I can only hear when rolling at idle speed, and it is once per rotation of the wheel. Any ideas?
Check the centercaps on your wheels.
CV boots can make some squeekie squishy sounds when roatating at low speeds especially with the wheels turned.
Rocks in your treads will drive you bonkos as well.
Make sure your front brakes are good. The metal sensors tend to rub slightly when off the brake and moving.
Kenny s>
Kenny s>
altydog
07-28-2015 10:20 AM
Jeffreynmandy
07-18-2015 08:26 AM
