turn signals flashers horn?
Old Feb 23, 2004 | 12:35 PM
black85toy's Avatar
Question turn signals flashers horn?
could someone help me fix these? my horn and flashers haven't ever worked. but today my blinkers quit, this is an 85 pickup and i checked all the fuses. thank you!
Old Feb 23, 2004 | 02:11 PM
User 051420's Avatar
For the flasher, check the actuall flasher module. Chances are, it's burned out. Get an electronically controlled flasher from an auto parts store.
As far as the horn goes...check the wires on the horn itself. Then peel back the part on your steering wheel, and see if that's swell.
Old Feb 23, 2004 | 04:14 PM
lunatic14r's Avatar
does your blinkers work if they do it is not your flasher if only your flashers dont work is proable the switch. as for you horn put a test light at the horn connector and hit the horn if the test light lights up your horn is bad if it does not it is the relay or the switch
Old Feb 23, 2004 | 05:59 PM
If I remember correctly, there is a seperate flasher for the hazard flashers. Maybe i'm wrong, but I'm pretty sure there is. What exactly isn't working?
Old Feb 23, 2004 | 06:00 PM
Ok so i re-read and the blinkers flashers DO NOT work.
Old Feb 24, 2004 | 05:06 PM
black85toy's Avatar
the turn signals work now i had the hazards switched on
where is the horn relay?
Old Feb 24, 2004 | 05:07 PM
black85toy's Avatar
oh yea the hazards still do not work
Old Feb 24, 2004 | 05:21 PM
amusement's Avatar
If the cab fuse was good then there's the possiblity of an in line fuse that has opened. Is the radio working? There's a black/white positive lead that feeds both the hazards, horn and radio.
If the problem was the relay the head lights also would be having a problem cause the horn, lights hazards are all tied into the haz/horn/light fuse relay (under the engine hood).
ghostmoney
Jan 28, 2018 11:42 AM
Shoua
13
May 22, 2016 05:19 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
PopsDad1
Jul 30, 2015 02:21 PM
