Tuning URD A/F Ratio Calibrator?
Old Aug 5, 2006 | 04:30 AM
mt_goat's Avatar
Originally Posted by Digger33
I just moved the numbers over on my a/f calibrator tonight. I'm running about 13.5 at 3psi in closed loop. I moved the numbers over two columns. I'm only getting about 5psi open loop at 5000 ft. though, so i think 13.5 at 3 psi is good.
Wow, is that with a 2.2" pulley?
Old Aug 5, 2006 | 07:44 AM
Digger33's Avatar
Yup that is with the 2.2 pulley. My boost gauge reads more, but on the ftc, which reads the MAP pressure, its only at 5psi. I think that may increase slightly once the temp drops from the 90's around here. I think at 5000ft you loose half the amount of boost, so 5psi isn't bad. It will just suck when you loose another half at 10000ft. You were at the co4rj last year right?
Old Aug 5, 2006 | 08:32 AM
mt_goat's Avatar
Yes, did I get to meet you?
Old Aug 6, 2006 | 10:49 PM
Digger33's Avatar
I'm pretty sure. I had the white tacoma that you were talking to me about because you had bought a similar one to pull the engine out of that was crashed in the front. I think we talked on wheeler lake where you were the only one to make it up that ledge. I just finally put it all together and realized you were at the jambo.
Old Aug 7, 2006 | 04:14 AM
  #25
mt_goat's Avatar
Oh yeah I remember talking to you now, cool.
Old Aug 22, 2006 | 04:28 AM
  #26
mt_goat's Avatar
Update on this: I cut the box lid for the serial cable: http://community.webshots.com/photo/...42310107hhLqiP
Then sealed it up with a hot glue gun: http://community.webshots.com/photo/...42310107HoREVz
Then wrapped it up for a bumpy ride: http://community.webshots.com/photo/...42310107zUJGkh
Many years of bumpy rides: http://community.webshots.com/photo/...42310107kSeeKQ
Hope this thing works now after all that :pat:
ladybugRC
458
Aug 21, 2020 10:41 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
the_supernerd
Oct 1, 2015 09:20 PM
Odin
Sep 26, 2015 06:56 PM
anniesball
Sep 5, 2015 08:45 AM
