Tube Bumper Design Begins...
Old Oct 20, 2009 | 08:29 PM
KrashDH's Avatar
It should be around 45lb before the aluminum filler...so whatever that adds. I'm tryin to keep it light because I have the 2.7...
Old Oct 21, 2009 | 01:34 AM
ESQ's Avatar
ESQ
Going to join the butt ends of the side tubes? Doing that would strengthen the sides immensely for only the weight of a couple inches of tube.
Old Oct 21, 2009 | 04:02 AM
4runnininMT's Avatar
"Thanks man, that's what I'm goin for the deer and elk here love to have parties in the road."
HAH! no joke at all...i find it an unusual day if i don't have to slam on the brakes at least twice on my run to and from town!
Old Oct 21, 2009 | 04:27 AM
98srx6's Avatar
Next you need to use solidworks to do FEA on your design. You may be able to remove/relocate some material to improve your designs functionality. Set your frame mounts as stationary points and then apply forces to different locations on the bumper to see where there are high stress concentrations.
Also, if you add weld to the joints in solidworks and set the material of each component to the correct material that you plan to use, solidworks will also give you the exact weight.
Looking good so far, keep us updated.
Old Oct 22, 2009 | 03:30 PM
  #25
KrashDH's Avatar
Yeah I actually plan on running that bottom one into the top one to crate a triangular shape
Yeah I was planning on using Cosmos to see where all the deflections would take place...I;m thinking of just mocking up the situation of me driving at different speeds and hitting a deer at different points and see what I get. I have a feeling the front is pretty solid, but we will see. I am going for lightness, so whatever Solidoworks enlightens me with I will probably change. I don't think I'll go as far as adding welds to the joints just because I'm not really planning on the welds adding that much weight in the end...it's like road bikers removing their shift indicators to get that extra half gram off their ride....
I got a couple more things to add tonight if I get em done I will post her up.
Thanks for all the comments guys!
Old Oct 22, 2009 | 06:58 PM
  #26
KrashDH's Avatar
Alright well my first attempt at rendering. This stuff is pretty tricky to get the materials to show how they should. The lighting has to be just perfect. I can tell this whole game will take a long time to get actually good at, but here is a mock up of the powde rcoat. I also put the skid on and bent those lower arms into the upper ones. Cheers!
punks_is_4x4
May 31, 2016 06:03 AM
firstgen88
Oct 7, 2015 04:53 PM
old87yota
Sep 9, 2015 12:39 PM
gp66
Sep 7, 2015 08:29 AM
dguzzi
Sep 3, 2015 08:48 AM
