TRD locker operation
Old May 12, 2006 | 02:47 AM
keithknepper's Avatar
I am considering purchasing a '04 TRD Tacoma, and tried to test the locker operation. With the truck in 4Lo, I pushed the button. The locker light flashed, but never went solid on. I drove it about 50 ft straight forward, light was still flashing. I did not want to do any more because I was on pavement.
Is this the correct sequence for engaging the locker? Should it have engaged & light gone solid on? Any other suggestions for testing? To my knowledge, the "grey wire mod" has not been done to this truck. Thanks!
Old May 12, 2006 | 05:47 AM
TRDOLMAN's Avatar
As you move forward, turn the wheel left or right a little. Works every time for me.
Old May 12, 2006 | 06:07 AM
ecchamberlin's Avatar
This is really the only slight down side of an e-locker. It can some times be a bit frustrating to engage. The light needs to be solidly on and the ABS light will also light up showing that that system has been bypassed. Every one i have used was a bit different but all had a little trick to make it lock faster. My 99 needed to be put into reverse to lock. I would give it another shot.
BTW I would not worry too much about the pavement. At low speeds (less that 5mph)on smooth pavement it should be fine. Once locked the inside rear tire will chirp a bit when you turn and this is actually a good way to check that it is working properly when looking to buy.
E-lockers are super tuff and the one you are looking at (04) should still be under warrantee any way.
TheBFA
Feb 15, 2020 06:55 AM
White Stripe
Oct 6, 2015 10:47 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
4runnerFireman
Sep 29, 2015 06:24 AM
83
Sep 27, 2015 04:13 PM
