transmission shuttering at cruise speed
Old Oct 7, 2009 | 06:35 PM
eugene's Avatar
FYI The symptom that I'm experienceing is; when going up long steep hills at speed 60-70 miles per hour when the truck downshifts out of O.D. it will shudder until I press the accelerator further and make the transmission downshift or lift off the accelerator for a second until the shutter stops. This is a intermittent problem. Thanks for any info.
Old Oct 7, 2009 | 08:47 PM
FogRunner's Avatar
What year is it and have you tried driving with it out of O/D (pushing the button on the shifter to lock it out) to see if the problem doesn't occur.
The 01-02 runners seem to have more problems with their O/D in the transmission going out causing a shuttering before total failure.
Old Oct 8, 2009 | 08:06 PM
Parker Runner's Avatar
Sounds like the gear which engages the OD is going. But then again, I just play a mechanic on the internet.
If it is, I would never pay for a tranny to be rebuilt. Just get another low mileage unit and keep on trucking.
Old Oct 9, 2009 | 04:59 AM
mt_goat's Avatar
Is there a lot of noise with this shudder?
Old Oct 10, 2009 | 10:46 PM
I had this happen with my Toyota camry wagon. I thought it was an engine out of tune. Sure enough-bad tranny.
Does it happen once the transmission heats up or all the time.
You may be hunting for a good used tranny.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
jake_v
Jul 22, 2015 03:17 PM
