Transmission Flush ?
Old Sep 10, 2006 | 03:56 PM
  #41
fireteacher's Avatar
cool, hope all is well
Old Sep 11, 2006 | 09:25 AM
  #42
frohbego's Avatar
Still getting a Thud / Knock !!
Ok so heres what i have done so far.
Oil Change
Front rear & diff change
Trasfer case change
Transmission change
Yesterday i Lubed all the zerks on the drive shaft and u-joints.
Today still getting the same thud / knock noise. I do not think its the transmission at all.. Shifts very smooth. But it sounds and feels like its from the driveshaft of the axle.
Also i got about 25 miles from home with out it doing it. Once i got off the highway on back roads it started up again. I noticed it when i slowed down and when the car downshifted. But it also does the thud/knock when i accelerate usally right after the car downshifts.
What should i do now?
Thanks for everyone help!
-JON
Old Sep 11, 2006 | 09:30 PM
  #43
Tanto's Avatar
Is your driveshaft dinged/bent a little? Is there any play in it if you put your hands on it and try to move it (not rotate it)
Old Sep 11, 2006 | 10:16 PM
  #44
kelsey22's Avatar
Question a little unrelated
soooo....my boyfriend changed my tranmission fluid today and it was definitely no longer reddish purple and it seems from reading posts that the fact that he changed it could be bad. AND his roommate who is a mechanic also said it was bad! = / What should i do? was this bad? I have a 95 toyota 4runner with 133k
Old Sep 12, 2006 | 06:06 AM
  #45
frohbego's Avatar
I'm not able to move he driveshaft and could not see and dings or dents.
Old Sep 12, 2006 | 01:51 PM
  #46
aowRS's Avatar
Originally Posted by Localmotion
alright, I just had the cooler line flush done. WOW, what an improvement on shifting. I havent ran into any problems.
Matt,
I had mine done today at Goss's Garage - it definately shifts smoother and the old fluid was nasty dark - 112,500 miles!
Andreas
Old Sep 13, 2006 | 01:16 PM
  #47
frohbego's Avatar
just had ny local shop guy take a look at it. The only thing he thinks might be wronge is that there may be too much play in the front drive/trans axle. He said jeeps have no play and wasent sure if the 4runners should?
Anyone know anything about this?
Thanks!!
-JON
Old Sep 14, 2006 | 11:28 AM
  #48
frohbego's Avatar
I also just noticed that the knock/thud happens more oftan and louder with the Air Conditioning on.
Old Sep 14, 2006 | 06:02 PM
  #49
http://www.gadgetonline.com/TransFlush.htm
good info
Old Sep 20, 2006 | 06:58 AM
  #50
frohbego's Avatar
I went 2 days with no knock/thud.... It still does it every once and a while but much lighter.
Old Sep 20, 2006 | 10:41 AM
  #51
i honestly do not think that there is anything wrong other than the typical thud most runners have! i wish they would figure out a fix and recall the SOB'S!!
at least you learned a few things along the way, right?
Old Sep 20, 2006 | 08:46 PM
  #52
frohbego's Avatar
oh yeah i forgot to mention.. I took it in to the local toyota dealer last week who are super nice and very helpful... They looked it over and said it checked out fine.. Drive train/axles.. are fine.... They even went over all my grease fittings underneath just to make sure i did not miss any... I think the grease deffiantly helped.
They also told me to go back to the place i had my front and rear differentials drained and have them add a rear friction modifier in the rear. Which they did.
So for now.. every once and a while when i apply the brake it get a slight thud in the front axle is seems... Usally happens on my way to a complete stop...
Thanks for everyones help
-JON
Old Sep 20, 2006 | 09:03 PM
  #53
frohbego's Avatar
also do i have the correct grease? - http://www.mobiloil.com/USA-English/...ic_Grease.aspx
Old Sep 21, 2006 | 08:29 AM
  #54
frohbego's Avatar
Just a heads up.. My thud is comming from the front axle.. It also only thuds when i'm slowing down. Down hill or braking for traffic...For example when i'm going 50mph and sow down to 30 or 20mph.. Not when i come to a comlete stop... Is this the same issue??????
Old Sep 21, 2006 | 10:37 AM
  #55
Gt4r97's Avatar
Hey, man i have the same issue with my 4Runner-a faint thud and only when slowing down for traffic light/stop and almost coming to full stop. But the "thud" go away after three to four stops-I think when the car warmed up. After that no more thud heard or felt. I've been lubing the driveshafts to the point that I even got good amount of grease splattered underneath. I've been able to live with it but sometimes it's really annoying thinking that something's not alright our there!
Old Sep 21, 2006 | 10:33 PM
  #56
frohbego's Avatar
Thanks Kent.... Mine mosty thuds when i'm going about 50mph and hit the brakes... Just to slow down.. Not fully stop and keep going...
Longbed 90
Mar 11, 2019 12:38 PM
LotOMiles
Sep 14, 2015 11:45 PM
Jwp1
Sep 6, 2015 11:03 AM
Squigglez
Sep 4, 2015 07:33 AM
kelly1450
Sep 2, 2015 12:29 PM
