Transmission Fluid Leak
1997 4runner 2WD 3.4L SR5 - 3 months of ownership ($6500 w/ 150K miles)
Anyhow, about a month or two after buying, started to notice a transmission fluid puddle under the center of the vehicle. Puddle gets bigger and bigger yet fluid level remains constant? Took a picture of where the leak appears to be coming from:
Right there at the rear end of the transmission, seems to be leaking out of the top "plug" all over the lower speed sensor and mounting damper. Here's another view:
you can see the net result is fluid dripping off the mounting damper - at least that's what I think is going on.
Would appreciate some input about that "plug" - put a wrench on the 12mm bolt and was plenty tight - plug seems to be hard plastic - would think it to be a place to check fluid level but can't figure out why it keeps leaking? Also, if I need to replace something, would like to know what it is called - but more than anything would like to see if anyone else has had a similar problem.
TIA,
Rick
TIA,
Rick
Agreed on that - although I am 99% sure it is coming from that plug - you can see pretty red fluid trickling right out of the seam - although the pictures don't show it.
I would have removed it to check for an O-ring already, but am worried I'll have a major spill on my hands - suppose I'll have to just do it and see what happens. I can't seem to find anything about that plug anywhere, though - which seems wierd in itself. Maybe somebody else has dealt with this.
jasonty
41
Dec 23, 2018 01:00 PM
the1998sr5
Jul 16, 2015 06:20 AM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
