Transmission Conversion
Old Sep 21, 2004 | 07:43 AM
does anyone know if it is possible to convert an automatic transmission to a manual
Old Sep 21, 2004 | 08:45 AM
Cebby's Avatar
Yes, it's possible. You may want to search Marlin's forum for more info.
board.marlincrawler.com
Old Sep 21, 2004 | 12:02 PM
awesome thanks for the help
Old Sep 22, 2004 | 03:28 AM
kyle_22r's Avatar
everything should be a direct bolt-in. you just might have to cut a new hole for your shifter to come up through. check through the junkyards and pick up a manual pedal assembly, it all bolts up
Old Sep 22, 2004 | 11:34 AM
will i still have cruise control or does that go throgh somewhere else
Old Sep 22, 2004 | 11:42 AM
You will also need a "new" ECU.
Old Sep 28, 2004 | 06:12 AM
how hard is an ECU to install
Old Sep 28, 2004 | 06:52 AM
Weasy2k's Avatar
unbolt, unplug plug in bolt in
Old Sep 28, 2004 | 03:10 PM
sweet action, will i have to weld shut the holes that my shifter is in right now and then cut new ones
Old Sep 28, 2004 | 03:16 PM
where can i get an ECU and a clutch assembly because i will need the slave cylinder for the clutch as well right
Old Sep 28, 2004 | 03:20 PM
Flamedx4's Avatar
Probably from the same place you get the transmission, shifter, and pedal assembly from...
Old Sep 28, 2004 | 03:35 PM
where is the best place, internet or somewhere local, junk yard or not
Old Sep 29, 2004 | 09:35 AM
Flamedx4's Avatar
The best way to do it is sell yours and buy a 5 speed rig... next best is to find a wrecked rig or one with a blown engine and buy the whole thing. Sell off what's left when you're done.
Old Sep 29, 2004 | 09:47 AM
Scottz's Avatar
Cool
I installed a 5 speed trans in my 94 4runner and removed the auto. I did not change the ECU but I did have to swap the trans crossmember and the driveshaft to the 5 speed set up. Doing the cluch peddles is fairly easy ,the firewall has an outline of the cluch master as far as location.
Bourbonblues
Dec 15, 2017 05:43 PM
Jwp1
Sep 6, 2015 11:03 AM
Wardog
Sep 6, 2015 07:57 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
kelly1450
Sep 2, 2015 12:29 PM
