transmission code 63
Old Dec 26, 2003 | 04:58 PM
Babypig's Avatar
Can anyone post the link to trans trouble codes. Did a search here and no luck.
Thanks
Steve
Old Dec 26, 2003 | 05:26 PM
ssyota's Avatar
Are you sure it is a transmission code? I found a code 63 as rf motor circuit. An abs code.
Old Dec 26, 2003 | 05:47 PM
ssyota's Avatar
Try, troublecodes.net/toyota/ or autorepair.about.com both tell you how to retreive codes and what they are.
Old Dec 28, 2003 | 08:28 AM
Babypig's Avatar
yes I'm sure it is a trans trouble code. the O/D light is flashing. The link you provided isn't for transmissions.
Old Dec 28, 2003 | 03:24 PM
JD's Avatar
JD
Trans code 63 is No 2 solenoid
Old Dec 28, 2003 | 04:50 PM
0n a 87 camry tranny code 62 is #1 solenoid or short circuit- severed wire harness or short circuit. From my own tranny code 61 I learned that I had a bad #2 speed sensor, severed wire harness or short, if these codes apply to a 1991 4runner. I would like to see if these apply. Try here. This is what I found on my extensive inet search. I am not advertising , btw.
http://autorepair.about.com/library/faqs/bl911g.htm
smthwsn357
May 1, 2024 07:28 AM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Aug 19, 2015 02:15 PM
nonstop
Jul 24, 2015 06:29 PM
mengquis
Jul 13, 2015 10:39 AM
