Transfercase counterbalance
Old Mar 18, 2009 | 06:31 PM
TacoNut's Avatar
The transfercase on my '04 Tacoma has a weight on the pasenger side that hangs down. What is the purpose of this weight? I searched and couldn't find any info. If I remove it what if any problems might I see? Just wondering, cause I bent it clear around this last weekend!
Old Mar 18, 2009 | 07:05 PM
DeathCougar's Avatar
It is not a counter balance, its a vibration dampner.
crolison's Avatar
post some pics
Old Mar 18, 2009 | 07:23 PM
TacoNut's Avatar
So, to keep down vibration at higher speeds? Do you know if it would cause any serious problems removing it?
Old Mar 19, 2009 | 06:09 AM
97ltd4x4's Avatar
That rubber coated weight is a "drive train dampener".Toyota put these type of weights on lots of different vehicals,They are basically a band-aid from a harmonic frequency problem during testing.Sometimes the "dampener" is bolted to transmissions/transfer cases/frames/exhaust systems..You will not hurt anything by taking it off,but you will possibly feel vibrations (vibrations that the dampener is trying to minimise) from the drivetrain under certain conditions.
1uzRunner
63
Nov 10, 2018 03:58 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
yoterr
Sep 15, 2015 06:26 AM
hodgepodge79
12
Apr 3, 2007 08:43 PM
hoosierhog
Sep 22, 2005 08:28 AM
