Transfer case grinding - 2000 4Runner
Old Apr 29, 2014 | 02:41 PM
Vackie's Avatar
4runnercollegekid, did you ever suss out your problem?
I have a '99 4runner auto with same symtoms as yours. Intermittent symptoms. Have checked/tested all vacuum lines/VSV's/front diff and TC switches for continuity. 12V tested the actuator motor on the pins and got it to lock and unlock the front driveshaft but now not working when i shift from inside cab. I want to pull the actuator and have a look see if rust is inhibiting its movement sporadically as my truck has been known to go through salt water. Did you pull the whole thing off to inspect or just the triangular coverplate? Any tips for looking at the thing would be appreciated.
Old May 23, 2015 | 08:31 PM
byg202's Avatar
ATF in multi-mode transfer case
Don't want to hijack any threads, but what fluid goes in the multi-mode transfer case (1999 t4r limited, auto, with the "AWD" push button on the shift lever). The manual calls for gear oil, ATF is what came out.
Old Nov 8, 2020 | 03:32 PM
Jtorress4R's Avatar
Did you ever figure out the problem?? I’m having same symptoms.
Originally Posted by 4RunnerCollegeKid
Hi all! I'm new to the forum, but far from new to Toyotas. Here is my problem:
I drive a 3rd generation 2000 4Runner Limited and am having issues with the transfer case. If it matters, my 4Runner has a factory rear locker and is the version that has a push button 4WD High selector on the side of the transfer case lever. Throughout the weekend, I have been going between 2H and 4H as needed (without using the push button) and everything has worked fine. Today, as I got back onto plowed roads, I moved the lever back into 2H, the dash indicator went out as it should have, and drove for about half an hour with no issues. About half an hour into my drive, I noticed the four wheel drive dash light blinking, as it does when the transfer case lever has been moved but 4WD has not yet been engaged/disengaged. Thinking I had bumped the push button and accidentally told it to engage 4H, I pressed it in and out and confirmed that I had not bumped anything. The light went out. A few seconds later, the light was blinking again and I started to hear a high pitched whiny grinding noise coming from either the transfer case or the front end. As I slowed down, the grinding continued and there was a loud clunk which shook/bucked the whole car. I got over to the berm, stopped, and shut the car off. I turned it back on and the dash light continued to blink. Trying to experiment, I pulled the lever back into 4H and set off again. I never heard it engage the front wheels and the dash light continued to blink. I then moved the lever back to 2H and a few seconds after began to hear grinding again followed by three more loud clunks that shook the truck. I pulled over again, then proceeded back to home with the dash light blinking, the transfer case lever in 4H (only position where grinding wouldn't happen), and the car actually only having power to the rear (as confirmed on a snowy road). Once back home, I drove around a parking lot putting the transfer case lever into all of the positions. In all cases, the dash light remained blinking, I never felt/heard the transfer case engage or disengage and the truck stayed in two wheel drive. In 4H, it drives no problem, in 4L, it begins to grind, in 2H, I could not get it to grind in the parking lot, but am guessing that it would if I got up to road speed again. The car is drivable, but the transfer case isn't working and I use four wheel drive regularly.
While I am fairly knowledge about vehicles and can do many repairs myself, I am a first year student at Allegheny College in PA and no longer have a warm garage in which to work or a parent's car to drive while mine is out of commission. Any help or insights you can provide are greatly appreciated.
Thank you,
Bennett
please let me know if you found solution.
mskalmus
May 28, 2017 07:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
