Tranny fluid over-fill?
Old Dec 15, 2004 | 06:36 PM
Pretacopower's Avatar
I was planning on adding some of the Sea Foam Trans Fluid into my auto tranny tonight to see if it would help my rough shifting, and when I checked the fluid level it was WAY above the two notches that it should be between.....and from what my Haynes manual says, thats a bad thing.
I haven't had my tranny fluid replaced since almost a year ago, so its been overfull since then.
Would this be to blame for my rough shifting? (i.e. when I manually put it into reverse the truck violently "lurches" and when I manually shift into drive I get this "ping!" sound.)
Old Dec 15, 2004 | 08:33 PM
TechWrench's Avatar
First, did you check with the engine running, in park, and at operating temp?
If not, this could give you a false reading. It is possible that too much fluid could make the trans act up, so if it is over full, drain out enough to bring it to the correct level and see if the problems go away. It can't hurt to try this first.
Old Dec 16, 2004 | 09:13 AM
The first time I checked it, it was at operating temperature but my engine was off. So I went out and drove it around some more and checked it with the engine running and it wasn't as overfilled, but its still a good 1/2 inch above the top notch.
I'll try draining it a little bit and see if that helps.
Thanks for the reply!
mordell
Sep 12, 2015 10:13 AM
VT2LAB
Sep 10, 2015 09:36 AM
old87yota
Sep 9, 2015 12:39 PM
eggens
Sep 5, 2015 12:16 AM
