Tranny cooler?
Old Aug 1, 2006 | 01:05 PM
stangman39's Avatar
Tranny cooler?
I've pulled a few times (no long distances..maybe 5 miles at a time...) my double trailer w/2 SeaDoos. Sometimes pull a single trailer w/one ski on it of course!
I have a '00 4Runner Sr5. How can I tell if it has the trans cooler and if not...should I install one for the little towing I do?
Thanks,
Mike
Old Aug 1, 2006 | 01:12 PM
vegaskurt's Avatar
It has a cooler, just not a good one. Toyota uses the bottom section of the radiator for a tranny cooler.
Do a search for hayden 676 or hayden 677. Cheap and easy install.
BajaRunner's Avatar
I think they all came with a stock tranny cooler.
It doesn't hurt to just add another one.
Old Aug 1, 2006 | 01:14 PM
mt_goat's Avatar
I would and did, and I don't even have a trailer. You should have a factory ATF cooler in your radiator, but that's not enough IMHO. Heat kills auto trannies, the cooler it is the longer it lasts. Just putting a cooler thermostat in would help some since the ATF is cooled by the radiator.
Old Aug 1, 2006 | 02:19 PM
stangman39's Avatar
Thanks for all the info.
I'll look into adding an additional one.
Mike
Old Aug 1, 2006 | 02:31 PM
Knuckles's Avatar
i got the TRD transmisson cooler, it easy to install and it just mounts to factory bolts, no zip ties. but of course it cost me alot.
Old Aug 2, 2006 | 07:41 AM
frodin1's Avatar
Hayden 678 $55 bucks on ebay.Two day shipping.
Old Aug 2, 2006 | 08:00 AM
04 Rocko Taco's Avatar
Any thoughts on comparison, pros/cons between the TRD cooler and the Hayden cooler? the prospect of using the factory bolts, and knowing its a factory peice has its great things, but money is a downfall, what else?
Old Aug 2, 2006 | 08:17 AM
mt_goat's Avatar
I like these: http://www.importperformancetrans.com/coolers.shtml
BTW they can be found cheaper on e-bay too.
Old Aug 2, 2006 | 08:46 AM
UNR.Grad's Avatar
Try searching you will see it is the SAME cooler.
Old Aug 2, 2006 | 09:28 AM
Epic Ed's Avatar
I bought a TruCool and have been very happy with it. Some good info here:
https://www.yotatech.com/forums/show...=tranny+cooler
Ed
Old Aug 2, 2006 | 09:50 AM
saulgoode's Avatar
I've read great things about the hayden cooler here, but the only thing I didn't was it has the plastic ziptie looking thingies that you can mount thru the radiator, but I didn't feel that it would be secure and just didn't like that either, so I got some 1/4 in. thick aluminum, cut some 3in strips and used that to mount the cooler to the metal piece in front of the radiator. Very secure now.
Old Aug 2, 2006 | 10:16 AM
mt_goat's Avatar
I agree, the Tru-cool comes with much better mounting hardware than the Hayden.
Old Aug 2, 2006 | 11:27 AM
MTL_4runner's Avatar
I used the zip ties.....no issues here as long as you use the foam isolators too.
I might have been nicer to hard mount it, but I didn't.
Old Aug 2, 2006 | 11:41 AM
vegaskurt's Avatar
The 677 I got off ebay came with metal mounting tabs/strips as well as the plastic ties. I used the metal strips, a few bolts and some loctite, its not going anywhere.
The plastic ties got used a week later on my civic
Old Aug 2, 2006 | 03:43 PM
ZUK's Avatar
ZUK
Thanks,
Mike
Mike- Doesn't sound like you need one.....even if you get an extra cooler you wouldn't really know how effective it is ...unless you have a tranny temp gauge to reference. So maybe the first thing you should consider is a temp gauge and watch it while towing. Driving "blind" without would makes me nervous without a gauge.
I recently installed a temp gauge and have noticed that on the highway at 80 mph that the temp stabilizes at 170 in my 2001 Taco. This is very acceptable for auto trannys but I want COOLER....When the weather cools, I will add the Hayden cooler behind the grill and see the improvement it actually makes. I have not towed with it yet so I don't know if the mild load of 2 SeaDoos will change it much.
Old Aug 2, 2006 | 08:43 PM
frodin1's Avatar
I think it was Transdude that said it on here,"it's never to late to add a cooler".
Old Aug 5, 2006 | 01:32 PM
BRYANINTEXAS's Avatar
9 out of 10 times, the TRD items are re-badged/packaged parts. (TRD air filter/K&N; TRD shocks/Bilsteins; TRD springs/Eibach; etc.... )
Old Aug 6, 2006 | 12:28 AM
UNR.Grad's Avatar
Yep some people get TRD kits with hayden labled coolers.
Old Aug 6, 2006 | 05:40 AM
mt_goat's Avatar
Speaking of Transdude, notice what brand of cooler he recommends: http://www.importperformancetrans.com/coolers.shtml
Better than TRD/Hayden at cooling and less restriction/pressure drop for the ATF flow through the cooler, win-win.
