TPS adjustment at a Stealership
Old Mar 7, 2004 | 12:09 AM
Hey guys,
Do you know how stealerships adjusst TPSs??? Do they use a computer or a method that's shown on 4crawler.com???
I'm asking cuz I've tried to adjust it myself by I couldn't get it right (I've tried at least 5 times).
Thanx in advance
Old Mar 7, 2004 | 06:36 AM
MTL_4runner's Avatar
Originally Posted by lesha30
Hey guys,
Thanx in advance
They don't use any special computers, just a multimeter like you would. I am not sure where you are running into problems but you just use the following table. Then do the tests but don't worry so much about the feeler guage. Do throttle closed, wide open, and hen vary the position to ensure you get linear readings across the full movement.
Table: 3VZ-E (3.0 V6) - TPS Adjustment Specifications
Test Clearance between lever and stop screw Between terminals Resistance / '89-'95 (ohms)
1. 0.00mm (0.000") VTA - E2 200-800
2. 0.50mm (0.020") IDL - E2 < 2.3K
3. 0.77mm (0.030") IDL - E2 Open / Infinite
4. Wide Open Throttle VTA - E2 3.3K-10K
5. n / a Vcc - E2 4.0K - 9.0K
Old Mar 7, 2004 | 07:43 AM
Spectre's Avatar
I see you didn't get the memo on the TPS reports... I will send you another copy
Old Mar 7, 2004 | 08:07 AM
hahahahahahha....
Longbed 90
Oct 19, 2015 11:05 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
dbollier123
Sep 29, 2015 05:23 PM
tysen86
Sep 25, 2015 11:15 PM
moparbay
Sep 3, 2015 12:48 PM
