Toyota RV engines: output and such
Old Jan 2, 2005 | 11:38 AM
okidoc's Avatar
Does anyone know the difference (if any) between the regular truck/4runner engines and the R.V. engines? It would make sense to me that the engines from the R.V. would produce more torque and Hp. I have seen a few R.V.'s around for cheap. If there is an increase in output what is the difference in design and is it transferable to my 3.0
Old Jan 2, 2005 | 11:49 AM
02SE's Avatar
They have the same HP, and torque ratings.
Old Jan 2, 2005 | 12:03 PM
DeathCougar's Avatar
same engine. Only difference is transmission....lower gears methinks for take off.
Old Jan 2, 2005 | 01:30 PM
kyle_22r's Avatar
the lowest geared toyota transmission was the R151F in 4x4s with the turboed 22RE. most of the others have a 3.93 1st gear, most 2wds have a 3.83 1st
i've heard some were fitted with aftermarket RV cams, but i wouldn't hold my breath
Old Jan 2, 2005 | 02:45 PM
Most motorhomes had auto transmissions too, i believe.
Old Jan 2, 2005 | 03:59 PM
Flamedx4's Avatar
My company built some of those teenie (and not so teenie) motorhomes on the Toyota chassis. All it was was the one ton, stretched, with a lower axle ratio. (4.10 IIRC) All were autos. They did surprisingly well for what they were. Being tall, I never cared much for them though. (Neither the standard cab legroom nor the small RV headroom and short beds...)
Old Jan 2, 2005 | 04:31 PM
3car's Avatar
Funny, I spotted an early 80's Toyota rv yesterday, and that went through my mind. I cant imagine that little toy engine powering a heavy rv with aerodynamics of a barn door.
It might be sufficient in flat Florida, but I cant imaging driving that thing out west up Donner or Cabbage passes.
Old Jan 2, 2005 | 04:33 PM
you could do it....at about 10 mph in first gear haha Those poor 20 and 22r engines were not really built to handle a motorhome, but companies like Dolphin made it work for them...and they were pretty popular.
Think of Uhaul! For the longest time, they used Toyota trucks and turned them into moving trucks.
Old Jan 3, 2005 | 08:16 PM
kyle_22r's Avatar
remember a common use for the 20R and 22R motors was in industrial forklifts...
Old Jan 3, 2005 | 10:00 PM
Flamedx4's Avatar
They did a surprisingly good job. But the gearing is part of the key. You do not EVER need to go 90 mph, so you gear it for max power and no top speed.
Old Jan 4, 2005 | 07:12 PM
kyle_22r's Avatar
also, all toyota trucks before '79 or so had at least 4.10 gears. they didn't really start having 3.08s, 3.42s or 3.54s much until the 80s.
Old Jan 4, 2005 | 11:33 PM
Flamedx4's Avatar
I really don't remember what gears the One Ton had, or what the RV chassis had. But it was screaming at 70 mph. Of course, it needed to...
Old Jan 5, 2005 | 01:42 PM
kyle_22r's Avatar
i'm 99% sure that the trucks labelled as 1 tons(e.g. 80s and early 90s) had 4.10 gears, and 4.30s as a towing option
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
