Toyota Guru Help Needed - Insane Starting Problem
Old May 14, 2012 | 12:30 PM
BC_4runner's Avatar
Exclamation Toyota Guru Help Needed - Insane Starting Problem
So I have a 1998 4Runner with the 2.7L 3rz that I tried to start this morning.
Engine started for a minute, then immediately died. After it died, it sounded like it was not making compression/timing chain was broken while it was turning over. I have heard the sound before and know it well, it was just turning over freely/without resistance.
It wouldnt even hiccup trying to crank. I got my buddy to crank and I confirmed that the chain/cams were turning, but it was not making the *thud thud thud* from each compression stroke while turning over.
After a 5 min or so, I cranked it for a bit and it fired up. Ran ˟˟˟˟ty for a bit, then cleared up. It runs as good as new now.
I unplugged the coils and turned it over and it made a solid *thud thud thud* that it should while turning over.
How does and engine not make compression, then make compression?!
THIS DEMON ENGINE DEFIES PHYSICS
Any suggestions would be grand, thanks yotatech
Old May 14, 2012 | 02:15 PM
BC_4runner's Avatar
Really, the whole post could almost be summed up as - "What could make an engine temporarily lose compression in ALL 4 Cylinders??"
I am quite mechanically savvy, but this one is driving me up the wall
Old May 14, 2012 | 05:44 PM
James Woods's Avatar
Are you positive that the engine is making the "no compression" sound? May be the starter spinning but not engaging the flywheel of flexplate, only way to tell is to have someone crank it while watching the crank pulley when it is acting up.
Old May 14, 2012 | 07:33 PM
BC_4runner's Avatar
I am 100% sure. Not only was the crank spinning, I took off the oil cap and watched the camshaft+timing chain spin as well.
The engine was turning over with no compression sounds
the1998sr5
Oct 19, 2016 12:48 PM
Crazychris1871
Jun 27, 2016 10:38 AM
Dennis140
Jun 17, 2015 10:37 AM
Old Red 94
Jun 16, 2015 08:32 PM
HALMAN
Jun 14, 2002 09:02 PM
