Toyota Electric Locker
Old Jan 21, 2003 | 06:49 PM
Cebby's Avatar
Will the 3rd Gen Electric Locker fit the 2nd Gen rear end? Do these units work in the front also?
Old Jan 21, 2003 | 06:57 PM
r2xj's Avatar
i asked the same question a while ago, here:
http://home.off-road.com/~kemanuel/elocker/elocker.html
about the front tho, i was wondering about that too
Old Jan 21, 2003 | 07:20 PM
Cebby's Avatar
Thanks for the link...
It mentioned the FZJ80 lockers (as in front and rear) That has solid axles, right. Anyone know what size the front diff is? 7.5" like the IFS diff?
Old Jan 21, 2003 | 08:56 PM
Adam F's Avatar
The elocker fits all 8" Toyota axles with some modifacation. It's not just a drop in. There is cutting grinding and welding and wiring involved. Definetly will not work for the IFS front end.
http://www.4x4wire.com/toyota/tech/electric_locker/
Old Jan 21, 2003 | 10:53 PM
Shane's Avatar
Re: Thanks for the link...
The FZJ80 front locker is an 8" high pinion unit and can be swapped (with housing mods) into a solid front axle pickup or 4runner, however it is not recommended for rear use. The rear is a larger unit and cannot be used, you have to find a locker from a Tacoma or 4runner for that application and you'll still have to do housing mods to fit it. None of the elockers will fit any of the IFS front diffs.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
coryc85
Sep 9, 2015 06:24 AM
Daneums
Aug 20, 2015 05:36 AM
A2theK
Jul 12, 2015 10:46 AM
