Toyota Aftermarket Switch??
Old Jan 17, 2011 | 06:03 PM
xxxtreme22r's Avatar
I still have to retrofit a 1st gen 4runner deck lamp switch into mine, but I got to look up the wiring diagram/colors on the switch.
Old Jan 17, 2011 | 06:22 PM
trevorrhine's Avatar
The lights draw more than that; but, by using the relay, all of the strain is placed on the relay and not run through the switch.
All the dash switch is doing when wired to a relay is activating the relay and using enough power to turn on the led on the switch.
Old Jan 17, 2011 | 06:29 PM
That makes more sense, it almost sounded like you had your lights wired through a 3-5 amp fuse.
Old Jan 17, 2011 | 06:36 PM
no way haha, the small fuse is just to protect the switch itself. You run a 20 amp or whatever u need from the battery to your relay.
Old Jan 17, 2011 | 11:17 PM
  #25
md_runner's Avatar
savage offroad also sells the factory switches btw
Old Jan 18, 2011 | 10:47 AM
  #26
rideexileex's Avatar
i think i ended up drawing power for the switch direct from the battery, with a 3/5 amp inline fuse...you could probably even get away with no fuse
If you are running a hard-line straight from the battery, you should always use a fuse. If not, you are just asking for shorts/fires, especially if the wires are not secured or are rubbing against abrasive objects.
The only time I ever wire something without my own fuse is if I know what +12 source I am tapping into, as it should be protected already by the factory fuse box.
Old Jan 18, 2011 | 11:00 AM
  #27
Also, this may help:
https://www.yotatech.com/forums/f2/f.../#post51562424
reference the picture in post one to see the order of which I am speaking, but these are 3 pin switches... I'm not aware of any OEM 4 pin switches?
Road Bull
Oct 10, 2015 04:55 PM
Gamble_STi
Jul 7, 2015 07:54 PM
colinmil
Jul 6, 2015 04:03 PM
Suprarossa
Jul 6, 2015 05:21 AM
Vargntucson
Jul 4, 2015 12:15 PM
