Toyota Aftermarket Switch??
Ok. I am looking to hook a couple of large off road lights on the front of my 2000 4Runner. I would like to mount the switch in one of those nice little knockouts in the dash to the left of the steering wheel. My question is, which switch fits best in this square cut out. I remember my dad's 98 Runner had a set of aftermarket fog lights attached to a switch that fit seamlessly in that spot. Does anyone know if Toyota sells a switch specifically made for this location? Or does some aftermarket company make a switch that fits in here?? Any help would be greatly appreciated! Thanks!
This should do it, Its not shown in pics but there is a PN http://www.ultimateyota.com/index.ph...26&topic=387.0
I used to run the factory switches but now use these;
http://www.4x4mods.com/Product/Jeep/...rswitch40.html
The back of the factory fog switch, I was wanting to know what prong was ground, hot and relay/fog but I found it and with the light at the top of the switch they go in the order I just stated.
Thanks, the search took forever b/c it's not just spelled out somewhere. I may submit it to the "All mods that can be done to a 3rd Gen" post so it's easier to find.
will they fit???
ive tried a few switches i have lights in front and back so i have four switches and the one i like best is the factory switch it lights up which is nice and it looks cleaner and more at home than any of the others did. plus it was like 8 bucks from the stealership
just go to oznium.com they have them for scions and they are exactly the same plus the face that they have them in different colors to choose from and just snap in and look completely factory. I use mine for driving lights and another for reverse lights. There only 12 bucks too.
Just wire it into the terminal for the switch on the relay you're using to power your lights. I would really recommend using a relay for lights because running 20 amps through your switch could melt it or cause a fire. Even if its rated for the amps, I would be weary to trust it. When u use the relay all of the amperage runs through the relay and the switch only needs like a 3 or 5 amp fuse to keep things safe.
