towing in overdrive?
Old Mar 22, 2007 | 09:11 AM
Beartracker's Avatar
Where I live in these mountains it's sometimes hard to judge whats best. Going up and down all day and having flat spots or straight aways where I can hit 60-70 for a few minutes and then have to slow down to 35 for a series of curves can be hard on the Tacoma. I'm driving with a 2.7 and auto tranny and it does great in these mountains but, shifting in and out of OD all day would drive you nuts around here. If I'm off road and doing 35 or less all day I will turn OD off. Never seen much difference when using the ECT button. Mike
Old Mar 22, 2007 | 07:29 PM
Joshs98Runner's Avatar
The ECT keeps the converter locked for the most part, which is beneficial for towing and hills. If you leave ECT off and cruise down the freeway, notice how when you hit the gas at 70 or so your torque converter will lock and bring you from like 2100rpm up to 2500rpm, and if you still need more power it will downshift to 3rd and put your well over 3k rpm, if you put ECT on you will run at that 2500rpm pretty consistant and your rpm shift points are higher. Those rpm examples are about what I see with my 3.4 auto.
Old Mar 23, 2007 | 04:02 AM
Thanks Josh , but I thought I read somewhere that you were not supposed to use it like that. It was just for faster takeoffs like when you are merging with traffic on a freeway. Do you notice much increase in gas consumption?
Old Mar 23, 2007 | 06:27 AM
Yota Tony's Avatar
I've always towed with OD off in any auto vehicle.
If your doing serious towing I'd get a good aux. cooler for the transmission. Sometime the factory incorporates a cooler into the rad but this really isn't enough for towing any sort of load.
I'd also put a transmission temp. gauge into the vehicle. Keep an eye on the heat that your trans is putting out.
Old Mar 23, 2007 | 06:39 AM
  #25
Smiling_Jim's Avatar
Trans fluid temp of...
350 degrees means failure.
Every degree above 200 degrees shortens the life of the fluid and the trans.
SO, OD towing is really dependent on trailer weight, since weight and incline drive up the temp.
So, if you want to use OD, get a cooler and a temp gauge, otherwise leave it out of OD.
Old Mar 23, 2007 | 06:48 AM
  #26
TFJ-4runner's Avatar
We towed about 900 pounds worth a furniture from Oklahoma to Georgia with OD with no problems. Ours is the 2000 Auto 3.4.
Old Mar 23, 2007 | 07:19 AM
  #27
gpcollen1's Avatar
I think the theme here is that of course the vehicle can do it. The question is should you ever do it without a temp gauge and cooler.
I don't usually tow in OD, but have a small cooler for mine but no temp gauge. I think I had better get one though...
Old Mar 23, 2007 | 08:02 AM
  #28
mt_goat's Avatar
Originally Posted by Kerby J
when in the city or taking off u should never and i repeat never use o/d because there is a crush sleev that works with the o/d and if u frequently tow in o/d, it will eventually crush it completely and then o/d wont work and u will have to have the crush sleev replaced and that can be cosly and ur o/d wont work untill u get it replaced
so dont tow around town or start off in o/d but after u reach crusin speeds u can turn it back on as long as u dont have ny hills comin up on the freeway
Huh? The auto tranny never starts off in OD anyway and rarely goes into OD in the city unless you're coasting to a stop or going pretty fast.
Old Mar 23, 2007 | 09:00 PM
  #29
Thank you, and as I was stating we did tow a decent amount of weight a long distance with no problems from the transmission.
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
rmill05
Sep 27, 2015 01:43 PM
Odin
Sep 26, 2015 06:56 PM
toyhaulert100
Sep 24, 2015 07:55 PM
