Torn inner CV boot. 3rd gen writeup anywhere?
Old Apr 16, 2005 | 10:16 PM
sschaefer3's Avatar
Carquest and NAPA re-mans are fine. They will not have factory boots but will be good joints.
You will turn your old axle in for a core.
Old Apr 18, 2005 | 09:34 AM
TStango's Avatar
Originally Posted by ScottyBean
now are you sure its torn and its just not leaking? do you have any kind of lift in your truck? mine has a 3" lift in the front with a 1" diff spacer. mine spit a bunch of grease, but it still runs fine.. when i start to hear it click then ill re-pack them.
I thought once the CV joint starts clicking, it means that permanent damage is being done. Mine clicks when in 4WD and seems to bind slightly in 2WD when steering at slow speed. I'm assuming it's spent but you are leading me to believe it's just dry. I did lose some of the grease out of it after replacing the boots. Maybe I don't need to replace the entire assembly but just need to repack the joint?
matmattmatthew
10
Feb 9, 2021 04:15 PM
Swampwalker
Oct 12, 2015 09:49 AM
toyotasaurus
Sep 24, 2015 03:30 PM
runnermedic
13
Sep 21, 2015 05:20 PM
mordell
Sep 12, 2015 10:13 AM
