top plate spacers?
Old Apr 8, 2007 | 12:41 AM
-MaTTi-'s Avatar
top plate spacers?
I would like to get 2.5-3" spacers which mounts ON top of the upper strut coil support plate and does not affect the actual spring rate/does not increase pre-load.
Are Cornfeds like these? http://www.cornfedsuspension.com/
I have heard Daystars are, but then I found picture of the kit (looks like 1,25" in+1,25" on): http://www.wheelersoffroad.com/96024rundstrlift.htm
and the other pic (looks better): http://www.daystarweb.com/ItemForm.a...e-9ff28dfd3aba
Any other brands?
Old Apr 8, 2007 | 01:55 AM
Tanto's Avatar
Bamachem on this board makes/sells 3/8" polyurethane pucks that go on top of the coilovers. 2 of them is around 1" of lift but you'll also need extended studs from a company like RevTek.
Old Apr 8, 2007 | 05:43 AM
shiftMX's Avatar
I thought Andy quit making those and Steve was the one who sold them?
Old Apr 8, 2007 | 06:46 AM
waskillywabbit's Avatar
Top Plate Spacers: http://www.wabfab.org/96024Runner/96...iftoptions.htm
Old Apr 9, 2007 | 01:42 PM
-MaTTi-'s Avatar
So, those top plate spacers seems to be same at 4Runner/Tacoma/Tundra/Sequia/FJ Cruiser.
I found some more: readylift.com, allprooffroad.com
Cornfeds and Daystar makes more preload to spring. I do not like to get stiffer suspension. Differential drop + limit straps = no problem, I think.
Old Apr 9, 2007 | 01:49 PM
AH64ID's Avatar
If you do a 3" top plate lift I would think that it would be VERY easy to overextend the CV as top plates add droop equal to their lift... I put a .75" on mine and love it.
Cornfed uses both.. I have his complete 2" lift, machined down to 1.75". He uses a 1" spring spacer, so small it wont effect the ride.. And a 1" top plate, that I had him machine down to what I wanted.
Old Apr 9, 2007 | 02:06 PM
potsy's Avatar
From: Ocean Beach, CA Five square miles surrounded by reality.
yeah i remember reading on here that anything more than 2 bamachem spacers (3/4" of spacer for about 1" of lift) on top of the strut would cause a problem.
Old Apr 10, 2007 | 12:58 AM
-MaTTi-'s Avatar
You are right. That is why I mentioned limit straps. With those I could adjust how deep it drops, to avoid problems.
Maybe I make mild suspension spacer lift + mild body lift... Maybe best solution.
Old Apr 10, 2007 | 07:46 AM
AH64ID's Avatar
The combo will be the best way to get larger tires... Say a 1" top plate and a 1" BL from 4crawler.com that would get you more travel, OEM ride and 2" more room for tires
Old Apr 10, 2007 | 01:12 PM
sschaefer3's Avatar
Yes I have the HDPE spacers that do not rust or corrode.
Old Apr 10, 2007 | 01:42 PM
-MaTTi-'s Avatar
Will these fit to 3rd gen 4Runner? http://www.central4wd.com/inventoryd...folder%7C32668
I know front spacers will, but how about rear spacers? Is the spring end diameter same?
Old Apr 10, 2007 | 04:12 PM
Midget96's Avatar
Just an idea I'll throw out there if you want a thickness that's not commercially available: If you have a drill press (or even a Dremel tool), you can make strut spacers in less than an hour in any thickness you want. It's really not difficult, and the materials cost less than $15/sheet that yields 4 spacers. The studs are wheel studs for a Honda ATV that you can get for ~$4/each (need 6). I have the part number written down somewhere...
A friend of mine cranked out the spacers we're using in less than 20 min. They fit perfectly and cost ~$6/pair to make.
Go to McMaster-Carr for the HPDE sheets. They come in a variety of thicknesses (1/4" - 5") and numerous grades of plastic.
PM me if you want the details for the diameter of the homemade spacers...
Old May 7, 2007 | 12:03 PM
-MaTTi-'s Avatar
Okay. I installed Daystar 1.25" top plate spacers, they lifted the front suspension about 1.75". Then I made 2" bodylift.
I think it looks cool now w/33x12.50R17:
Sorry, offtopic. But there is the same suspension under KZJ90 than 3.gen 4Runner.
Old May 7, 2007 | 02:29 PM
Photog's Avatar
Man I wish they sold MiniCruisers in the USA. It would be much better than the RAV4's.
Cool rig. It looks great with the lift.
Old Aug 24, 2007 | 09:45 PM
KZN185W's Avatar
Matti,
what brand and size of wheels does your Prado have? Also what's the backspacing?
Thanks,
Roy
Old Nov 23, 2007 | 12:46 PM
-MaTTi-'s Avatar
Originally Posted by KZN185W
Matti,
Thanks,
Roy
Sorry, I´m late a little bit.
Wheels are Dotz Luxor, size 8x17", offset 0. I don´t have measured backspace.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
terminator
Jul 27, 2015 07:13 PM
TDonkey
Jul 26, 2015 10:14 AM
