too much boost?
Old Dec 11, 2003 | 03:07 AM
kimchee's Avatar
too much boost?
recently my boost gauge is showing increased boost levels.
I have a second gen supercharger and it was always very consistent at 6 pounds of boost.
recently i have been reaching as much as 8 pounds according to the boost gauge. This is usually at wide open throttle.
should i be concerned?
Old Dec 11, 2003 | 07:10 AM
Gadget's Avatar
It is normal for that to happen in colder weather. I hit 10 PSI sometimes with my opened induction system.
Gadget
www.URDUSA.com
Old Dec 11, 2003 | 02:58 PM
My99's Avatar
Cold air has more Oxygen in it, and yes, I agree, this is normal. Just make sure you're not running lean because of it.
Old Dec 11, 2003 | 04:08 PM
Gadget's Avatar
Well, not really. The O2 content is still about 21% no matter what the temp is. It is more dense at colder temps. What that means is that the engine can intake more dense air on each cycle and can make more power from it.
It is like you are on a mountain. The air is less dense, and only so much power can be made. Now go down to sea level and it is more dense because the pressure is greater and the engine can take in more on each cycle and make more power. The same thing happens with temp. I think it is called Henry's Law about how a gasses density changes as its temp changes.
You are right, but not completely.
Gadget
www.GadgetOnline.com
Old Dec 11, 2003 | 04:18 PM
My99's Avatar
Ummm... yes, dense = more compact = more O2 in a given volume when the air is colder, thus it can be thought of as taking a bigger "bite" with the same size mouth when the air is colder.
Old Dec 11, 2003 | 06:43 PM
Gadget's Avatar
EXACTLY!
But, the percentage of O2 is the same.
Gadget
shisha1999
Mar 3, 2016 07:09 PM
calderp
Nov 16, 2015 02:49 AM
RatOmeter
Oct 22, 2015 03:17 PM
viesail
Sep 21, 2015 06:00 AM
ManyMods
12
Feb 15, 2011 02:36 PM
