Tires Rubbing??
Old Aug 23, 2009 | 07:15 PM
jwhalen123's Avatar
Question Tires Rubbing??
Hi,
I have an 01 Millennium edition 4runner with 16x10 mickey Thompson M/T classics and stock sized BF Goodrich All Terrain T/A's. Mickey Thompson states that the tires should not rub but they rub every time I turn my wheels. I haven't really heard of the front suspension bagging on these vehicles but I haven't searched a ton either. The yota has 92K, could the front springs be shot or is Mickey Thompson lying? Also, does anybody now the stock ground height for this model and the best place to measure from to check? Also I can't seem to find stock front suspension for sale anywhere, any reasons why?
Thx.
Jeff = Newbie
Old Aug 23, 2009 | 08:14 PM
dannomite's Avatar
If it is rubbing when you turn I would suspect incorrect backspacing. If it rubs while going over bumps I would start to look at the suspension. What size of "stock" do you mean? I ask because that rim seems a little wide for a 265.
Old Aug 23, 2009 | 08:30 PM
Elton's Avatar
10'' wide wheel that could cause some problems too if the back spacing ain't right
Old Aug 23, 2009 | 08:32 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
Your 16x10's are most likely causing the problem. Your stock tire should be about a 10.50" width, way too skinny for a 10" wide wheel, even a little too skinny for an 8" wide wheel.
Old Aug 24, 2009 | 04:03 PM
crolison's Avatar
16x10's....... theres your problem. i'd have to have 14.50 + inch wide tires to run those
djpg2000
Nov 11, 2020 04:56 AM
Jamie4runner2000
Jun 20, 2016 09:13 AM
Williamemslie
14
Oct 5, 2015 09:28 AM
Scatterbrain
Sep 3, 2015 06:46 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
