Tire Size Question (15 inch wheels)
Old Oct 7, 2003 | 03:38 AM
Matt's Avatar
What are the largest size tires I can put on my stock 15 inch wheels without having to do any other modifications and also without them rubbing? I have a 2002 SR5 4Runner 4X4. It's not lifted and has the SR5 fender flares (not the limited ones) and running boards. Thanks!!
Old Oct 7, 2003 | 04:33 AM
waskillywabbit's Avatar
Tire Size
I think, and someone will correct me if I mispeak, I am sure! , that the largest size tire you can put on there with no rub on a bone dry stock rig with 15" rims is 265/75/R15s.
Brian
Old Oct 7, 2003 | 06:38 AM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Almost, the largest is 265/75R16's, depending on the rims you have. For 15", waskillywabbit is correct at 265/75R15.
Old Oct 7, 2003 | 06:50 AM
Matt's Avatar
How does 265/75/R15 compare to 31/10.5/15?
Old Oct 7, 2003 | 07:00 AM
jacksonpt's Avatar
Senior Member
Depends on the brand...
Pick a tire you're interested in and go to that tire manufacturer's website. Look up the tire and check out the sizes it comes in. That will tell you the actual measurements (diameter and width) fo the tire.
From what I've seen, 265/75-15 is a hard size to find... most manufacturers make a 31/11.5-15 instead, which is basically the same size.
Old Oct 7, 2003 | 07:18 AM
Matt's Avatar
So either 265/75/R15 or 31/11.5-15 is the largest tire size I can go with that won't rub?
Old Oct 7, 2003 | 07:19 AM
jacksonpt's Avatar
Senior Member
crap, sorry... I had a type-o in my previous post. it should read 31/10.5-15, not 31-11.5-15.
Old Sep 2, 2009 | 07:09 AM
JWaldz's Avatar
very rarely you can find metric tires in a 15" wheel at 265/75... most manufactures make them for a 16" wheel. You're best bet and the biggest you can go would be the 31x10.5R15 bc i honestly think to get a 265/75/15 would cost you more. I have no clue about the Chevy. I think i read somewhere that they come with 265's so i dont see why you cant get away with a 285 (or in your case a 33") they might rub a little though. Don't quote me on this, I know very little on chevy specs.
Old Sep 2, 2009 | 07:22 AM
94Runner4x4's Avatar
wow, very old thread
Old Sep 2, 2009 | 07:29 AM
hjkmotor's Avatar
Originally Posted by s.o.a.p.
Alright, so I have a chevy colorado 07 sock on 15s. I need as big as I can get and I have search everywhere! Please please help!!!
i thought this was a toyota forum
Old Sep 2, 2009 | 08:00 AM
JWaldz's Avatar
haha wow, it is.. I didnt even notice that.
Old Sep 2, 2009 | 04:20 PM
Ironmike4x4's Avatar
The answer to both is 31" tires. I test fitted a 32" on mine and it rubbed on the upper A arms.
Old Apr 15, 2010 | 11:01 AM
hungryeddy's Avatar
Sorry to bring out an old post... but what about a 17" wheel? no lift (yet)... whats the biggest?
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
Yotoder865
Jul 9, 2015 07:51 PM
