Timing Question
Old Feb 8, 2003 | 10:15 PM
AgRunner06's Avatar
Timing Question
I found out the other day that my timing was retarded by at least 15-20 degrees. It was way off. Apparently the mechanic who did my head gasket recall did not set it. Now it seems like I have less power. It is set right on 0 degrees now. Will adjusting my timing change my power?
Thanks for the help.
Old Feb 9, 2003 | 03:10 PM
ravencr's Avatar
According to what I've heard, the answer to your question is yes. Advancing your timing to a point will increase your power. But if advanced too far, you'll induce pinging.
Chris
Old Feb 9, 2003 | 04:47 PM
supascout's Avatar
I had a similar experience with my timing and I set it to 10* BTDC as my manual recommends! Big performance difference. Someone on the board told me that people with the 3.0 have had luck with 12* so you might try that. Just be sure that the timing is set with the computer disconnected, engine warm and idle at 800rpm.
good luck
_travis
Old Feb 9, 2003 | 06:12 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
When I had my 3.0, I had the timing advanced to 12 Deg.. There was a noticeable difference in towing power.
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
