Timing belt replacement: 3.4L
Originally Posted by AJatx
Every two revolutions are consistent, but the crank is one tooth ahead of the cams. Both cams are aligned in relation to the markers and themselves. So, basically, since there seems to be slack on the water pump pulley, it's always adjusting to be a tooth off.
Should I move the crank one tooth back so that when it tightens the belt off the water pump, it'll align?
J
J
"Should I move the crank one tooth back so that when it tightens the belt off the water pump, it'll align?" YES
They must be lined up exactly as you turn the engine over.
It seems to help setting the crank one tooth back.
When the crank is aligned with the marker, the cams are lined up with their markers within +/- 0.25 tooth. After 10 revolutions with tensioner applied, everything lined up.
So, I was sure it would run great this time around. It runs a lot better, but there is a slight studder at very low rpm (lower 1k range) with very light throttle (like backing out of my driveway). .Between 2krpm to 3krpm with 0 - 2 psi of boost , the truck runs great. It runs fine with 5psi of boost. At the highest gear, WOT, 6psi of boost, around 1.5krpm, it studders a little bit. It's hard to tell if it'll persist since I let off as soon as I feel the engine studder (or miss).
I've noticed that I can hear the timing belt during warm-up. It's a little noisey.
Do I have it on too tight? There wasn't much deflection between idler#1 and crank.
Maybe I need a video of it
J
J
Originally Posted by Dan_90SR5
Also, this might be a huge favor to ask, but if you have to break it down, can you send me as many good pics of the upper idler pulley? I need to know how it's mounted.
AJatx- you shouldn't be seeing any belt shavings at all. Did you get the belt guide plate (looks kinda like a big washer) put back on the crank in the right orientation? It has a slight concave curve on the edges that would dig into the belt if put on backwards.
#25
I put the guide on according to the picture.
I went through my old pictures and found that I put it on backwards.
The current pic shows reversed.
J
J
This pic he posted shows where the upper idler pulley bolts up. Right below the upper radiator hose connector and right above the water pump pulley.
#27
Belt guide is fixed, but the light throttle at low rpms studder is still there.
I checked the sparkplugs and they all look good. I noticed the prongs had some bluish color on it. Most of it looked new.
So, I definitely know I'm off a tooth again. Man, it's fustrating.
J
J
Sep 4, 2015 09:27 AM
