View Poll Results: Which locker setup should I go with?
Automatic (EZ or Lockright)
22.29%
Selectable (OEM or ARB)
73.49%
Other (please give me more info!)
4.22%
Voters: 166. You may not vote on this poll
time to get LOCKED!
Old Mar 20, 2006 | 11:37 AM
  #101
bamachem's Avatar
$500 obo really means about $500 shipped. add $200-$250 for labor to install and another $200 for a compressor. $900 for an ARB installed is a smoking deal. not as cheap as a lunchbox, but not in the same class either.
just thought i'd pass them along...
Old Mar 20, 2006 | 11:47 AM
  #102
lee's Avatar
lee
The ARB was gouged from a broken r&p. The damage is only on the surface and did not affect how the locker works in anyway. The r&p was repaired and the locker was run for 2 years so I know it works perfectly.
the heck is r&p?
Old Mar 20, 2006 | 11:48 AM
  #103
bamachem's Avatar
r&p = ring & pinion = gears...
  #104
FilthyRich's Avatar
ring and pinion
doh,,,Andy beat me to it
Old Mar 20, 2006 | 11:49 AM
  #105
wjwerdna's Avatar
ring and pinion is my guess
  #106
bamachem's Avatar
slowpokes.
Old Mar 20, 2006 | 11:50 AM
  #107
wjwerdna's Avatar
oops, shoulda F5'ed
Old Mar 20, 2006 | 01:26 PM
  #108
jeremys73's Avatar
$500 for ARB? Not a bad deal. What is the installed price of a lockrite?
Old Mar 20, 2006 | 01:32 PM
  #109
lee's Avatar
lee
...its the cost of a lockright if you install it yourself, which i plan on doing (with help from NE4ROC-ers)
Old Mar 20, 2006 | 02:24 PM
  #110
wjwerdna's Avatar
keep us updated for sure, but you knew thata I initially voted e-locker because thats what Ive planned on doing since I got the vehicle, but in case I can swing a "buy one with one and swap the axles" I cant do that, and I'm pretty much planning on a Lock-rite this summer now.
Old Nov 7, 2006 | 07:50 PM
  #111
chadbobb's Avatar
what makes installing a e-locker so hard? I know you have to switch out the whole axel right? Why is that so hard? Do you have to weld stuff in to make it fit? (not arguing, just tyring to learn)
Old Nov 7, 2006 | 08:18 PM
  #112
d0ubledown's Avatar
theres a write up on it. not sure of the link, but its easily searchable. in a nutshell, you have to grind out a bit of the housing, the opening when the 3rd member fits in. the rest is bolt in...well aside from the wiring of course. you can either go full oem and fit it with your computer if applicable. or you can fab up your own wiring. the swap looks like its not super easy, but not as difficult as putting in an ARB id imagine which requires tearing apart your carrier & resetting your R&P
Old Nov 8, 2006 | 07:52 AM
  #113
00Runner's Avatar
It's not hard if you replace the whole axle assembly. It's just harder to find a whole axle assembly w/e-locker to swap. If you don't swap the whole axle then you have to modify your existing axle housing which requires some fabrication (welding, cutting, drilling, tapping).
Old Nov 8, 2006 | 08:52 AM
  #114
spaugh's Avatar
lock right 195$ shipped, installed in half a day. Never look back.
I wonder of all the people who voted selectable (minus the people with factory e-lock) have forked over the money for one or can afford to shell it out. It's easier said than done to spend that kind of money with the less expensive options out there.
Old Nov 8, 2006 | 09:37 AM
  #115
bamachem's Avatar
not all have, but some have. i'm the exception - i have TWO.
Old Nov 8, 2006 | 11:50 AM
  #116
mpavolka's Avatar
Sorry to bud in but you guys seem to know what you are talking about. Why are automatic and locked rear differentials bad in the snow and ice?
Old Nov 8, 2006 | 12:32 PM
  #117
spaugh's Avatar
The idea is that if one wheel starts to slip in the snow, the locker will engage. I don't really see why this would be a problem unless it started to make your rear end swing around (fishtail). If you drive slow and cautious it prabably isn't that big of a deal. I don't ever drive in snow living in SD, so I really don't mind the auto locker.
Old Nov 8, 2006 | 01:33 PM
  #118
lee's Avatar
lee
that is the problem -- the fishtailing.
i havent ran in the snow with my lockright yet, but up till now it has been absolutely perfect.
Old Nov 8, 2006 | 04:29 PM
  #119
rcars4life's Avatar
I am thinking of buying a donor truck to swap axles (a locked donor) What Years would work? I am looking at a 1988 4runner thats locked, could i do that swap. meaning are the axles the same?
Old Nov 8, 2006 | 05:24 PM
  #120
NPE701's Avatar
I'm pretty sure 4Runners didn't come factory-locked until 1996.
