View Poll Results: Which locker setup should I go with?
Voters: 166. You may not vote on this poll
time to get LOCKED!
Do what I did: Buy an e-locked donor rig, swap the entire rear axles out with one another, and then sell the donor rig the same price you bought it for.
Of course in my case I had to swap front and rear thanks to the ratio difference.
Originally Posted by lee
selectables are SO expensive.
im just not sure its worth the price gap.
Total Price = $400
Having a locker = Priceless
Good Luck!
mike, thanks, thats a good piece of advice.. to do it once.
but wow thats a crapload of money. i want a rear locker only for now, and id like to do it on the cheap.
#25
go with the ARB. I want to keep my OEM traction control doo-das for the snow and ice here...and have the option of selectable locking diffs when needed.
It's more money...I have to save a bit longer..but in the end I willl be doing the right thing...ONCE! (instead of constantly changing/upgrading).
-B
-B
#26
You should also keep in mind that an auto locker will wear your tires significantly faster. You have MT/Rs so that's a lot of money that you'll be wasting inadvertently that could be spent on a selectable locker.
#28
i have a lot of reading and responding to do, but let me just say that when i state i want to do it 'cheap' its relative. im not saying im retarded and dont understand that wheeling is an expensive hobby... nor that i dont know that wheeling a 3rd gen = higher cost of parts in most cases. i know this.
but im looking to improve offroad performance while not breaking the bank. sounds like a detroit ez may be for me since i really cant spend the money on an arb right now.. especially since i want to lift higher, regear and get bigger meats....
ill keep thinking.
thanks for the responses everyone.
ill keep thinking.
#29
Originally Posted by calrockx
a proper install is critical tho.
#32
I adapted my driving style to my Lockright- light, positive throttle on turns, etc. I have rotated my tires frequently (Maxxis Mudders) and I do not think I have caused any more wear than the set I ran before I installed the locker.
I am not trying to discourage the purchase of a selectable locker, because I really believe they are the best choice. I am merely stating that, when driven properly with a full time locker, the vehicle performs very well on pavement. The only time I notice it, is during evasive or non-routine manuvers in traffic, like pulling out uphill in a turn quickly.
As for snow and ice, I have no experience or comment, but I'm sure that icy conditions would be a considerable deciding factor.
#33
As far as wintery roads, I drove a total of 3 hours in a snowstorm up here a month back, on hardpacked highways, in 4wd, doing 45-50 and I forgot completely about the lock right, it didn't bother me at all, until someone mentioned it just recently, it hadn't even occured to me that I was driving that fast with a locked rear end on hardpacked snow. I think that if you are a little careful and if you know how to drive, you won't really even notice it and any changes that need to be made in your driving style will happen subconsciously.
If the question is selectable or automatic and money isn't an issue, then yeah, go selectable, but since that is never the case, go automatic. If I knew back when my Taco was my dd and my wheeler what I know now, I would have bought a lockright before anything else.
#34
exactly.. im pretty much counting on doing it myself.
the other problem is, in my attempts to save up enought to get a selectable, i know i will see these wads of money (lets say $500 after a while) and be like... HMM I COULD USE RIMS! HMMM, I COULD USE MORE LIFT! HMMM, I COULD USE 285'S!
i dont think i could hold onto the money long enough!
You racka disaprin!!!!
#38
lee-
I've been in the same boat for awhile now. With 2 kids, I don't get to wheel nearly as often as I'd like, and my '01 is my primary DD. The expense of an ARB is out since I can't justify the cost. A lunchbox has a more appealing $$$, plus I can install it myself. I only question a lunchboxes on road characteristics (clicking, shuttering, etc). Excessive tirewear doesn't appear to be much of an issue with the new lunchboxes.
I've narrowed it to three options:
Not long ago, I emailed Aussie directly asked if they were actively pursuing a locker solution for a 4 pinion 8" model Toyota 4Runner (3rd Gen). Here's Aussie's Engineering response:
The other thing I've learned is that an LSD coupled with our VSC/A-Trac system may be nearly equivalent to a full lunchbox since the ABS system will automatically engage on the spinning wheel forcing more power to the wheel with traction. I haven't invested much time looking at this yet, but if it does prove to be true, an LSD on road manners are much more appealing than a full locker.
- Aussie - Not currently available for a 3rd Gen
- Power Trax System (Richmond Gear; a.k.a Lock-Right) - Not currently available for a 3rd Gen
- Detroit EZ
and an LSD: - Detroit TrueTrac
Yes, we are, and in fact have been for some time, looking at options on the development of a 4 pinion Aussie Locker for the V6 Toyota. The issues, as defined by our Australian engineering team are not insignificant due to our design approach. At this time we have three or four other new models that are ahead of the Toyota V6 in the que for new product resources so we are unable to provide a reasonable estimate of availability. We hate to send a customer to a competitor, but we also would not want you to have false expectations on availability from us.
#40
Originally Posted by Intrepid
If you call Powertrax/Richmond, they will let you know the model number that fits. There is one for the 3rd gen.
