Tie-rods, Pitman/Idler arms question
Old Nov 24, 2002 | 01:29 PM
Korrupted's Avatar
I need to replace the Tie-rods, Pitman and Idler arms on my 92 p/u. I was wondering if anyone makes them aftermarket. I want something stronger than the OE parts. Thanks!
Old Nov 24, 2002 | 10:37 PM
joshik's Avatar
heres an ifs rebuild... not a replacement but its a start
http://www.off-road.com/toyota/tech/idler/index.html
Old Nov 25, 2002 | 03:41 PM
Korrupted's Avatar
Thanks Joshik! That's gonna save me about $100!!!!!! I didn't know I could just rebuild it. And of course the shop didn't mention it.
Old Nov 25, 2002 | 03:59 PM
joshik's Avatar
that'll be $50! hehehe just kidding... im glad i could help. check out this site... has lots of cool stuff...
check out the tech archives on the left
tell us how it goes!
Old Nov 25, 2002 | 04:09 PM
Korrupted's Avatar
If you lived here I would buy you a 12-pack! I have that site saved. I never thought to look for Idler tech. Thanks again. If I remember I'll let you know how it goes.
Old Nov 25, 2002 | 04:10 PM
joshik's Avatar
coolcool!
Old Nov 26, 2002 | 11:37 AM
Korrupted's Avatar
I am also replacing my tie-rod ends. Will I need replace the adjuster sleeve or can I re-use the old sleeve. I have also heard about about after market sleeves from Fab-Tech. Is it worth buying and where can I find them?
Old Nov 26, 2002 | 11:39 AM
Korrupted's Avatar
Josh- a couple of us from Wild Yoats had no clue about the re-build until you told us! One guy has replaced his Idler a few times. Thanks again!!!
Old Nov 27, 2002 | 04:25 PM
Korrupted's Avatar
Yet another ? I looked at my idler arm and...
When turning the wheel the arm doesn't rub the frame. But you can see that it has rubbed at the bottom of the frame during articulation. Do I need to replace the whole unit or can I just re-build it? Thanks!
Old Nov 28, 2002 | 09:34 AM
crash's Avatar
As long as the sleeve is not marred on the tie rod, then I would just re-use it, since those are not what commonly fails. If you have any rubbage due to the idler arm, by all means replace it, sine it keeps the centerlink from being able to move up/down.The weak link I have seen on the Ifs part of the steering, is the idler breaking, and what a POS to deal with on the trail(my advice, replace it and carry old one as a spare)
Old Nov 28, 2002 | 09:38 AM
Korrupted's Avatar
Thanks 4 the help!
bigjstang
Jun 2, 2025 03:56 PM
rusty904
Mar 27, 2017 05:20 PM
andrewtexas123
Jul 6, 2016 01:49 AM
kirkrunner
Jul 27, 2015 07:59 PM
1994toyota
Jul 17, 2015 03:03 AM
